New Rancho shocks all around, but confused - Nissan Armada Forum: Armada & Infiniti QX56 Forums
Go Back   Nissan Armada Forum: Armada & Infiniti QX56 Forums > Armada Technical Discussions > Suspension/Tires/Brakes
Old 12-06-2012, 01:56 PM
steveg_nh steveg_nh is offline
steveg_nh is on a distinguished road
So after upgrading my tires to Firestone Destination A/Ts (wow is all I have to say about those), I'd like to upgrade the poor excuse for OEM shocks with Ranchos.
I want to put RS9000XLs in the front and rear. I don't have a rear leveling suspension. This is a non tow SE, 2008 4WD. According to various sites, the part numbers are
Rear: RS999306
Front: RS999771
But I believe these are shocks. I thought the armada has struts in the front. Or maybe I don't understand fully the replacement process. Or maybe I'm just mistaken entirely, in which case, my humble apologies!
The only reason I care, vs just bringing it to the auto shop and saying "have at it" is because they're letting me order my own parts and bring them in, and they'll just install them. So I want to be sure I'm buying the right stuff, and everything I need.
Any help/clarification is appreciated.
2008 Armada SE 4x4 w/Leather, Comfort & Conv. Package, M&D DVD System
Old 12-06-2012, 02:02 PM
Pops's Avatar
Pops Pops is offline
SHIFT_Moderator
Pops is on a distinguished road
The front are Coilover Shocks.
http://en.wikipedia.org/wiki/Coilover
A coilover is not to be confused with the shock absorber and spring setup (strut); coilovers are totally independent and do not require extra parts e.g. bumpstops, ball Joints, spring cushions etc. Many people state that they are the same but this is a busted myth, hence the reason that high performance cars use independent coilovers to increase road grip, handling and comfort. On a lower budget, people will install a 'lowering kit' consisting of a spring that is of different measurement in length (mm) and fit aftermarket shock absorbers to increase comfort and handling on tighter corners where body roll may hinder performance. Coilovers come adjustable or a fixed length and normally bolt straight to a car instead of using tools (spring compressors) to fit a shock absorber and a spring to. While they are generally more expensive (up to 90% more), they still offer the greatest amount of comfort and handling compared to the earlier, strut-mounted type.
- Bob
2005 Armada LE 4x4
Old 12-06-2012, 03:27 PM
I never knew that, but looking at them, it completely makes sense! So the spring gets reused I assume? So really, you do just order shocks all around.
I can't wait to feel the improvement with those shocks vs my worn out OEMs.
Old 12-06-2012, 03:52 PM
Pops's Avatar
SHIFT_Moderator
Yes... You use a Heavy Duty Spring Compressor to take them off and move them to the new shocks. It's much faster to just pay a shop $40 to move them over for you
- Bob
2005 Armada LE 4x4
Old 12-06-2012, 08:11 PM
My auto shop said $65 each to do the whole job. Sounds good to me!
Do you know if I have to worry about needing anything special to use these? They seem like direct replacement, not requiring modifications.
Old 12-10-2012, 01:33 AM
Kooshtaka's Avatar
Kooshtaka Kooshtaka is online now
Kooshtaka is on a distinguished road
Rancho makes direct replacement shocks for our trucks for both the front and the back. I'm not sure on the exact ones you purchased as I don't have a tremendous amount of experience with ranchos.
'05 Mada LE Slate, Bilstein 5100s in front, R1 Concept Premium Drilled and Slotted Rotors, PosiQuite pads, Removed middle row center console, 8K HID Lows, LED on order with Armaden , besides these she's just about bone stock
Old 12-10-2012, 03:07 AM
blackArmada_Dxb's Avatar
blackArmada_Dxb blackArmada_Dxb is offline
blackArmada_Dxb is on a distinguished road
Yup, the part numbers sound just about right. Here are the part numbers straight from Rancho's website:
http://www.gorancho.com/shock_lookup...dels&x=44&y=11
RS9000XL SERIES SHOCK Rear RS999306
RS9000XL SERIES SHOCK Front RS999771
  #8
Old 12-11-2012, 12:41 PM
So outside of buying the shocks, any other special parts needed? Since they appear to be direct replacement, doesn't seem like anything custom would be needed like larger washers, etc, etc?? Thanks.
