Aftermarket 4.56 or 4.11 gears? - Nissan Armada Forum: Armada & Infiniti QX56 Forums
Go Back   Nissan Armada Forum: Armada & Infiniti QX56 Forums > Armada Technical Discussions > Engine/Drivetrain
Old 01-25-2012, 12:15 AM
skynyrd skynyrd is offline
skynyrd is on a distinguished road
Is there anyone out there making aftermarket gears for the Armada? I am looking for 4.11 or 4.56 gears for a 2011 4x4 Armada. Lots of info out there on the Titan but I can't find anything on the Armada. Any info would be appreciated.
Old 01-25-2012, 07:50 AM
Scorpion's Avatar
Scorpion Scorpion is offline
Scorpion is on a distinguished road
I never heard anything. I wanted to put a true track and it's not possible the Armada's rear end is different then the Titan
Sent from my Autoguide iPhone app
2012 Titan PRO4X S&B cai, 2* Advance Timing, 6500k HID, 1000w sub with 500w rms amp, 18" XD RockStars with 33" BF Trails, BD GT, Volant Double Exhaust,
LED interior,
------------ROB-------------
Old 01-25-2012, 10:21 AM
scr38's Avatar
scr38 scr38 is online now
SHIFT_Administrator
scr38 is on a distinguished road
While the rear differential assembly is different on the Armada and Titan due to the IRS on the Armada, the ring gear and pinion are the same. Of course both the rear and front gear set must be replaced.
Changing the ratios will cause some problems. Cruise will no longer work, the speedometer will have problems, and probably other problems. Vehicle speed is monitored by sensors in the transmission and from wheel speed sensors. These two signals are usually the same, but when you change the gear ratio they are different. The system sees this as a problem, and could cause transmission shift problems, etc.
Old 01-25-2012, 12:32 PM
AngelVivas's Avatar
AngelVivas AngelVivas is online now
AngelVivas is on a distinguished road
What do those numbers mean for the gears? Is this only necessary when going with bigger wheels/tires on a lifted truck?
Angel Vivas, III
2006 Nissan Armada SE 4x2 Silver Lightning
Old 01-05-2013, 09:20 AM
mspeedrider@aol.com mspeedrider@aol.com is offline
mspeedrider@aol.com is on a distinguished road
Is this true. Has anybody done a gear swap. If they make it for the titan why wont it work for the armada. They share the same engine, trany, and computer?
Old 01-05-2013, 10:54 AM
rsoto80's Avatar
rsoto80 rsoto80 is offline
rsoto80 is on a distinguished road
because the armada uses an independent rear suspension. Titans are a straight axle.
04 Nissan Armada all stock
06 Dodge Charger R/T
13.8@101mph
Old 01-05-2013, 12:41 PM
But the ring gear and pinion are the same. So it should be the same right? My Question is "Changing the ratios will cause some problems. Cruise will no longer work, the speedom will have problems, and probably other problems. Vehicle speed is monitored by sensors in the transmission and from wheel speed sensors. These two signals are usually the same, but when you change the gear ratio they are different. The system sees this as a problem, and could cause transmission shift problems, etc." Dont the titan and armadas have the same trany, computer and engine.
  #8
Old 01-05-2013, 02:47 PM
rsoto80's Avatar
I guess it could work...go ahead and try it and let us know how it goes.
Not many people customize armada to that extent of changing gearing. Most just put wheels, exhaust, intake, and maybe a sound system. Gas mileage is our biggest disadvantage so changing the rear to a higher ratio would be the worst thing you can do to these trucks.
13.8@101mph
