power stearing hose - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 6 Old 11-07-2012, 11:32 PM Thread Starter
nv269
Quoted: 1 Post(s)
nv269 is on a distinguished road
power stearing hose
Has any of you replaced this hose?? if so, how much do you think it will cost, i am thinking of doing it myself, or should i have the dealer do it, when the dealer sells it, is it just one hose? any help is greatly appreciated. thank you.
Click image for larger version
nv269 is offline
post #2 of 6 Old 11-08-2012, 12:10 AM
ntrddragn
ntrddragn's Avatar
Quoted: 117 Post(s)
ntrddragn is on a distinguished road
it is leaking? did you identify whether the leak is from the hose or just the crappy oem clamp? here is what was posted on titantalk.com. and from the sound of it, it will cost you around 300-600 at the dealer.
First take the battery out of the truck this will let u get to the bolt that connects the hose to the pump. Disconnect the sensor then take the bolt out (there is going to be two washers on each side replace them when you reinstall the new hose). Let the old hose drop to the ground install the new hose with the new washer at this time (cover the other end (Steering gear assembly) with something so it won’t get dirty when it touches the ground) and connect the sensor. Go under the truck (remove the skid plate if you have one) and follow the old hose you will see it is held by a clamp with two screws. Take the screws out then open the clamp to get the old hose out after that you will see where the hose goes into to the Steering gear assembly remove it. Install the new hose that should be hanging from the pump before you attach the hose into the Steering gear assembly put some oil on to the O ring. Install the battery and add some fluid then remove the air from the system add more fluid if necessary.
The pump has to be running for the line to have pressure so no there is no pressure TitanBlue. it is not that hard to do if you have a simple set of tools. i did it in the parking lot of my appartment at night and i didnt know nothing about my titan then 2 years ago. Thanks to nissan now i know a lot more that a regular owner of a vehicle should know. i drive an 04 titan
here is the link: http://www.titantalk.com/forums/tita...ng-hose-2.html
'04 LE
ntrddragn is offline
post #3 of 6 Old 11-08-2012, 12:17 AM Thread Starter
nv269
Quoted: 1 Post(s)
than you so much, yes it is leaking, not a lot, but i would like to change before. i will give it a shot, do you know if this is hose is sold by itself or does it come with more things.
nv269 is offline
post #4 of 6 Old 01-07-2013, 08:15 AM
littledrummerman
Quoted: 2 Post(s)
littledrummerman is on a distinguished road
i replaced my high pressure hose in about 45 mins. now the reservoir hose is leaking going to try replacing the factory clamps
littledrummerman is offline
post #5 of 6 Old 01-07-2013, 11:36 AM
Pops
SHIFT_Moderator
Pops's Avatar
Quoted: 40 Post(s)
Pops is on a distinguished road
I had mine replaced under warranty.
- Bob
2005 Armada LE 4x4
Pops is offline
post #6 of 6 Old 01-08-2013, 10:40 AM Thread Starter
nv269
Quoted: 1 Post(s)
thanks, i am still deciding whether to do it myself or take it in.
nv269 is offline
