does it do it for every dvds? if yes, then the laser on your player is dying or dead. time to replace it. and if this is a copy dvd, it might not be readable, or that this particular dvd is too scratch.
I have a brand new DVD I bought from the store. It works fine in the house, so it must be the laser. My armada is a 05, where don't get the DVD player to replace at? Thanks
So no dvds play? U can get an oem from the dealership or courtseyparts. Com I believe there are aftermarket ones but im not sure which one would be a plug and play.
your dvd player is beyond its useful life. it is not worth the cost to fix. even if you can get a dvd to play in there, the warning signs are already showing and it will be a matter of time before it completely locks up (perhaps with your disk inside).
if you want to replace with a factory dvd, you can try second hand shops, craigslist, ebay, junk yards.
I had the same problem several years ago. I was advised by the forum to go to ebay and purchase a factory replacement. Its easy to replace (5 screws hold the console under the rubber mat if I recall). Been working since.
My 2007 DVD/Entertainment unit stopped working recently. The unit would not change source mode and would take but not keep a disk. It would repeatedly fail to read and spit the disk back out. I just purchased a NEW (not refurbished) replacement unit for $349 on EBAY. I will post how it works after I install it.
Thanks for the links - Luckily my monitor works fine (holy cow $550 for just the monitor?)...I am replacing the DVD player unit that came in the center console...brand new unit received UPS today. I will attempt install tonight and report back.
Replace was an easy job. 2007 Armada has a faux floor inside of the center console. Underneath there are 3 screws. On top rim driver's side there are 2 more screws (may have had rubber feet over them at one time but mine were missing/screws exposed). Once 5 screws removed the entire liner of the bin, the lid AND the attached DVD player lift out. Be careful not to pull the wires too hard. There are 2 plugs that go into the back of the DVD player...remove those and the entire unit is free. Switch out the player (several screws to remove from the brackets) and plug back in. Test and re-install the liner with the new DVD. No programming required for the wireless headphones and remote control (they must be programmed to a different component of the system).
Works like a champ so far! $349 for my brand new replacement. They also sell refurbished or service the units. http://stores.ebay.com/Original-Car-Audio-952-707-6200. Looks like they also sell the DVD navigation units as well!
Related Threads
291.4K posts
39.8K members
Since 2004
