White Smoke solved. - Page 5 - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #41 of 44 Old 10-03-2016, 05:47 PM
chiarmada
chiarmada is on a distinguished road
Thanks to the forum our 2008 Armada smoke issue is resolved. It has 113,000 miles on it. I had the engine oil flushed with a cleaner of some sort, new covers, gaskets, PCV's and spark plugs. My Indi Mech said there was a bit of sludge clogging where the oil drains back down from the valve train. There is a baffle that keeps the oil from going up the PCV valve too. If the oil return holes get clogged, oil builds up and is sucked into the intake via the PCV valves. I replaced the PCV's first and it helped for 1 day then back to smoking. The whole service including diag, intake remove and cleaned, oil flush, new covers/gaskets and spark plugs was $ 852.87. I will return for another oil change at 114,000 miles and they will drop the oil pan and clean out any remaing stuff, about $ 175 for that. Now for the rear air suspension ....
chiarmada is offline
post #42 of 44 Old 11-17-2016, 06:14 AM
mparkerjr
mparkerjr is on a distinguished road
I'm having the exact same issue with my 2012 Armada. The dealership says the motor needs replacing. There apparently seems to be sludge in the crankcase and they said it was because of running past routine oil change intervals.
I've read many posts from the web and just curious what can cause the sludge buildup besides non-frequent oil changes. This is a used vehicle with 56,000 miles and is immaculate. I have records where they took to dealership for cabin filter changes, can't imagine the oil wasn't changed regulary.
Thanks for any help.
Click image for larger version
mparkerjr is offline
post #43 of 44 Old 11-17-2016, 10:36 AM
PetitFrereArmada
PetitFrereArmada's Avatar
Quoted: 148 Post(s)
PetitFrereArmada is on a distinguished road
Is that the actual picture of your motor?
That truly looks bad.
My Build/Maintenance/Modification thread..., Aiming for 250K on odometer.
2012 Infiniti QX56
... KING OF THE ROAD
2008 Nissan Maxima SE
... CATCH ME IF YOU CAN
PetitFrereArmada is offline
post #44 of 44 Old 04-20-2017, 02:39 AM
vegas_speedster
vegas_speedster is on a distinguished road
I just had the same problem with my 06. It seemed like overnight it started smoking during startup. Then it actually got worse when I could see smoke when I took off from the light too fast. If I shut the truck off; and then restarted it 5 minutes later; it would fill the parking lot with smoke until the engine burned off the oil.
I tried new pcv valves; they worked for about a day. I tried an engine flush. Nope. Even sea foam.
Finally when I had time, I bought the valve covers, and gaskets and did it right. The passenger side rear is the hard part. The three bolts in the rear are hard for anyone with large hands. Anyway I haven't had a puff of smoke in over a week now. There is a nice tutorial on YouTube. Just google it.
2006 Graphite Black Armada
kenwood ddx6019/kgna-510 navi/gxm-30 smart antenna with XM
2003 350z
tanabe gf210 springs
volk 20" gtc's
kenwood ddx7017/kgna-510 navi/gxm-30 smart antenna with XM
injen exhaust
jwt popcharger
zainoed
vegas_speedster is offline
