Status
Not open for further replies.
How To Read And Reset The SES Light
79K views 0 replies 1 participant last post by  scr38
#1 · (Edited by Moderator)
If your SES (service engine soon) light comes on you can read out the trouble code and reset it by following this procedure.
In-car ECM Diagnostics/ECM Reset procedure:
1) Sit in the driver's seat.
2) Turn the ignition key to the ON position and wait three seconds. (Do not start the car.)
3) Fully depress and release the accelerator pedal five times in less than five seconds.
4) Wait exactly seven seconds. Fully depress the accelerator pedal for ten seconds until the SES light flashes.
5) Release the accelerator pedal and start counting flashes to obtain the four-digit trouble code.
Long flashes (0.6 seconds) indicate the first digit of the code; count the blinks one through nine and write down the first digit. (Ten blinks indicate a zero.)
The next three digits follow in turn in the same fashion except with faster blinks (0.3 seconds) and a 1.0-second pause between digits.
The ECM code repeats itself until you turn the ignition key to the OFF position, at which point the ECM resets itself to standard get-in-and-drive-the-car mode.
Additionally, if you get four blinks out of ten (0000), the ECM is indicating no malfunction.
You can clear the code (and the annoying SES light) by holding down the accelerator pedal for more than 10 seconds while the SES light is blinking. When you release the pedal, the ECM erases the trouble code(s).
Attached is a list of the Nissan Codes.
See less See more
1
Status
You have insufficient privileges to reply here.
