Tire Pressure Monitoring System - Nissan Armada Forum: Armada & Infiniti QX56 Forums
User Tag List
post #1 of 59 Old 03-28-2007, 12:50 PM Thread Starter
scr38
SHIFT_Administrator
scr38's Avatar
Quoted: 37 Post(s)
scr38 will become famous soon enough
There has been a lot of discussion (and some mis-information) about the TPMS on our vehicles. I hope this will shed some light on the subjuct.
Each of the four tires on the ground has a pressure sensor in it. There is no sensor in the spare; the system can "read" only four sensors. This sensor is built into the tire valve stem. Each sensor sends a pressure signal by radio to a receiver in the dash, the same one that receives the keyless entry system signal. These signals are then sent the the Body Control Module (BCM). The BCM controls the low tire pressure warning light and buzzer.
If the TPMS system receives a low pressure signal from one or more wheel sensors the light and buzzer will go off. If the system is not receiving 4 signals from the sensors it indicates a system problem and only the light goes on.
Contrary to what others have posted, you can't turn the system off.
In fact, there are Federal laws concerning this:
Congress passed the Transportation Recall Enhancement, Accountability and Documentation (TREAD) Act in the fall of 2000. This requires a warning system to indicate under inflated tires.
Automakers had to be 70% compliant by September 1, 2006 and 100% compliant by September 1, 2007. (Section 13 of the TREAD Act).
By Federal law (49 U.S.C. 30122(b) the TPMS system can't be bypassed:
"A manufacturer, distributor, dealer, or motor vehicle repair business may no knowingly make inoperative any part of a device or element of design installed on or in a motor vehicle or motor vehicle equipment in compliance with an applicable motor vehicle safety standard prescribed under this chapter..."
It is not against this law to remove sensors yourself, but a shop could refuse to work on any vehicle that violates this law.
Many of the larger tire stores now stock the sensors and repair parts. The car makers seem to be setting a standard for the sensors, so most will interchange. The tire stores also have the programmer to activate the sensors.
The TPMS is a good thing. It could save you a wheel, tire, prevent an accident or even save your life. I urge everyone to keep the system intact. If you get new wheels, install sensors in them.
If any sensor other than the ones that came on the vehicle are used, they must be programmed to your vehicle. You can move sensors from your original wheels to new wheels without having to reprogram them.
Also, it is not necessary to reprogram sensors when the four tires on the ground are rotated. You don't use the spare in the rotation since there is no sensor in it.
I hope this answers questions about the TPMS.
scr38 is offline
post #2 of 59 Old 03-28-2007, 04:40 PM
esMada
SHIFT_Hardcore
esMada's Avatar
Quoted: 0 Post(s)
esMada is on a distinguished road
I agree with you 100% scr38.... it is one safety feature I love having in my truck. and since I have a Nav. it displays this warning everytime I start the vehicle until I inflate the tires back to the proper pressure.
esMada is offline
post #3 of 59 Old 03-29-2007, 08:21 AM
Bcrowell
SHIFT_Lurker
Quoted: 0 Post(s)
Bcrowell is on a distinguished road
I have a question regarding TPMS and aftermarket rims.
How are the sensors programmed? Do they have to remove the tires from the rims?
My question relates to the purchase of Infinity QX takeoffs or other aftermarket used rims with the sensors installed.
Bcrowell is offline
post #4 of 59 Old 03-29-2007, 09:28 AM
Chris03HD
SHIFT_Hardcore
Chris03HD's Avatar
Quoted: 0 Post(s)
Chris03HD is on a distinguished road
Such a great system.... to bad it cant tell you what damn tire is which on the display!
GM (*gasp*) even shows a LF RF / LR RR on their displays..
Chris03HD is offline
post #5 of 59 Old 03-29-2007, 10:53 AM
92TripleBlack
SHIFT_Hardcore
92TripleBlack's Avatar
Quoted: 0 Post(s)
92TripleBlack is on a distinguished road
Good post scr38.
92TripleBlack is offline
post #6 of 59 Old 03-29-2007, 11:01 AM
bmfsapper
SHIFT_Hardcore
bmfsapper's Avatar
Quoted: 1 Post(s)
bmfsapper is on a distinguished road
My Brother has some aftermarket rims on his Titan and got old ones installed in them and no reprograming was needed but that might have been a special case dont really know if is same for all. anyone?
The only issue he had was that the istallers were and damaged 2 of them in the process. Now we are putting on two from a Mada and will post what was need to get full function. Well actually bill be using info posted by SCR38.
2005 Nissan Armada SE 4x4
"Sappers Lead the Way"
bmfsapper is offline
post #7 of 59 Old 03-29-2007, 04:57 PM
Mada300z
SHIFT_Newbie
Mada300z's Avatar
Quoted: 0 Post(s)
Mada300z is on a distinguished road
I would have to give the vote to Nissan on this one. It is a little more of a PIA to find the problem but when it shows up you don't just put air in the one tire (GM) but you have to test them all to find the low one. Makes for an all around safer system.
04 Armada LE 4x4 no Tech
Kenwood DDX 6019
M&D ANS190ST
JL Audio 500/1
Custom Stealth box for Eclipse 10"
Audiovox rear view camera
93 300ZXTT
Sport 500 Turbos
555cc Injectors
Ashpec ECU
SS Split Downpipes
Jim Wolf Pop Charger
Hard Pipes
Greddy Boost Controller
Mada300z is offline
post #8 of 59 Old 03-29-2007, 05:01 PM
Chris03HD
SHIFT_Hardcore
Chris03HD's Avatar
Quoted: 0 Post(s)
I dont agree with that statement at all.
Id like to know WHAT tire to add air to, if the other 3 are reading correctly.
Unless you can eye ball the difference between 33psi and 36psi, Nissan should have followed GM's lead.
post #9 of 59 Old 03-29-2007, 05:18 PM
Mada300z
SHIFT_Newbie
Mada300z's Avatar
Quoted: 0 Post(s)
By checking I mean with a guage of course.
You are certanly entitled to your opinion however if that system told my wife which tire to add air to she would never even check the other ones until told to do so. If there was something wrong with the other sensors she would never even think to look at the other tires. Since the Mada is her daily not mine it's safer for me this way. Hell, she can't even remember to get the oil changed and the sticker is right in front of her face. Having to check all of the tires means looking at all of the tires and maybe even seeing other problems like treadware, missing lugs or sidewall damage. I just think its a good reminder to check them all while your out there and you might find something you were'nt looking for. I certainly don't need the TPMS on my 93Z but she's not alowed to drive that.
Kenwood DDX 6019
M&D ANS190ST
JL Audio 500/1
93 300ZXTT
Sport 500 Turbos
555cc Injectors
Ashpec ECU
SS Split Downpipes
Hard Pipes
Mada300z is offline
post #10 of 59 Old 03-29-2007, 05:33 PM
esMada
SHIFT_Hardcore
esMada's Avatar
Quoted: 0 Post(s)
When I put after market rims on my Armada, the tire shop took the sensors off my stock wheels and put them on the new ones. The light came on and they told me to drive it around the block and it would turn off..... it did.
BTW, I agree that it would be nice to know exactly which wheel is low but since it is not this way, I feel safer checking them all. It's actually a good reminder for me to check my tire pressure.
esMada is offline
Linear Mode Linear Mode
