im pretty sure they are ptc( push to connect fittings. air pressure must be release first then push air line in and hold ring on connector and pull air line out
Removal and Installation EES001HJ
REMOVAL
1. Remove the wheel and tire assembly using power tool. Refer to WT-7, "Rotation" .
2. Use CONSULT-II “EXHAUST SOLENOID” active test to release the air pressure from the rear load leveling
air suspension system.
3. Remove the four clips and remove the rear fender protector, front.
4. Disconnect the rear load leveling air suspension hose from the
shock absorber.
To disconnect the hose, push in on the lock ring using a suitable
tool and pull the air hose out.
5. Remove the shock absorber upper and lower end bolts using
power tool.
6. Remove the shock absorber.
CAUTION:
Do not damage the rubber boot on the shock absorber.
INSTALLATION
Installation is in the reverse order of removal.
Tighten the shock absorber bolts to specification. Refer to RSU-25, "Components" .
INSPECTION AFTER INSTALLATION
Check the shock absorber for any air leaks or damage to the rubber boot.
Check the shock absorber for smooth operation through a full stroke, both compression and extension.
Check piston rod for cracks, deformation or other damage and replace if necessary.
LEIA0081E
LEIA0082E
In the morning there was very minimal air in shocks. When I released the ptc valve very little air came out. Sure there is another way but this worked for me. Just make sure shocks feel deflated.
The correct way to release the air is to use a scan tool, something like an Autel that can access all the modules. Once you hook up the scan tool and you have selected your vehicle you go to special functions and activate the button labeled "exhaust solenoid". Nothing to it.
Related Threads
291.4K posts
39.8K members
Since 2004
