VDC light, brake and slip light all on??? - Nissan Armada Forum: Armada & Infiniti QX56 Forums
User Tag List
post #1 of 28 Old 11-03-2008, 10:02 PM Thread Starter
vindicator
SHIFT_Lurker
Quoted: 0 Post(s)
vindicator is on a distinguished road
Last week the VDC, brake and slip light all came on and stayed on. I took it to the dealer who reset the system and said it should probably have all the wheel sensors replaced and the the brake fluid changed since it looked dirty??
In less than a week the lights are all back on. This is on an 06 LE Mada with only 36K highway miles. Also, they want $450 plus tax for the above repairs if I let them do it. No thanks. Going to take it to my local mechanic next week. Appreciate any of your opinions and advice. Thanks. Vin
vindicator is offline
post #2 of 28 Old 11-03-2008, 10:28 PM
BlakSpyda
SHIFT_Moderator
BlakSpyda's Avatar
Quoted: 5 Post(s)
1st, check your brake fluid level and fill it if needed. (Most usual suspect)
2nd, you might need brake pads
3rd, check this link.
http://www.clubarmada.com/forums/showthread.php?t=6394
BlakSpyda is offline
post #3 of 28 Old 11-04-2008, 02:19 AM
cpaul
SHIFT_Hardcore
cpaul's Avatar
Quoted: 0 Post(s)
cpaul is on a distinguished road
I have NEVER seen all of the wheel speed sensors go bad. I have had to change two before but that was only once in all the years I have been working on Nissans, and other makes. Sounds like someone does not know how to diagnose problems. You need to find a mechanic that is NOT a PARTS CHANGER. Those types of people give the rest of us a bad name.
If you can't fix it with a hammer, you've got an electrical problem!!
08 Pro4X, Superchips Cortex Tuned, Air box mod, Backup camera with gps, Rear Axel Tube Vent mod, Bug shield, ???
cpaul is offline
post #4 of 28 Old 11-04-2008, 09:23 AM
Campfamily
SHIFT_Hardcore
Campfamily's Avatar
Quoted: 122 Post(s)
Campfamily is on a distinguished road
Quote:
Unfortunately this type of behavior (PARTS CHANGER) is more the norm than the exception these days. If you find a true mechanic, hang on to them for dear life, because they are few and far between. cpaul, I sure wish you were in my neighborhood, because our local Nissan dealers could sure use somebody like you!
- 12 Armada Platinum 4WD, Tuscan Sun (red)
- 06 Armada LE 4WD, Red Brawn, QX56 Wheels (traded)
- 04 Armada LE 4WD, Smoke (lemon lawed)
- 15 Ford Focus Electric (commuter car)
- 00 Maxima SE, Manual Trans (kids car)
- 65 Buick Skylark Gran Sport Convertible, 401 ci, 2nd owner, original condition, 70,000 miles (play car)
- Prowler Lynx 826M Travel Trailer, 26', 5000#'s
"How often we fail to realize our good fortune in living in a country where happiness is more than a lack of tragedy."
--Paul Sweeney, author
Campfamily is online now
post #5 of 28 Old 11-06-2008, 06:11 PM Thread Starter
vindicator
SHIFT_Lurker
Quoted: 0 Post(s)
Thanks for your opinions guys. You supported what i already suspected but I needed to hear you tell me I was given bad advice. Its discouraging to have a new dealership have a tech make an incorrect diagnosis and have the Service consultant who was just promoted from being a tech, tell me they were sure it needs all new sensors and fresh brake fluid. Fluid it full, pads are fine. I just finished an 800 mile drive and these three light came on after 50 miles. After sitting overnight the lights are off now. I think its more a computer or electrical problem.Idiot lights on or off the brakes work the same. Am I right that its not a safety issue as long as I am not driving on slippery roads?? Vin
post #6 of 28 Old 11-06-2008, 06:18 PM
BlakSpyda
SHIFT_Moderator
BlakSpyda's Avatar
Quoted: 5 Post(s)
As long as the brakes are working mechanicly, there should be no safety issue on dry pavement. However, vehicles today are so integrated that an electric, computer, or sensor issue can make if unsafe through faulty operation.
post #7 of 28 Old 11-06-2008, 06:54 PM
Driftwood
SHIFT_Lurker
Driftwood's Avatar
Quoted: 0 Post(s)
Driftwood is on a distinguished road
I had the same problem with my 04. The dealer replaced all pads, replaced front rotors. Who knows what else. The lights have not come back since.
2004 Nissan Pathfinder Armada LE
Driftwood is offline
post #8 of 28 Old 11-06-2008, 10:55 PM
Flacko
SHIFT_Lurker
Flacko's Avatar
Quoted: 0 Post(s)
Flacko is on a distinguished road
I had the same problem, I had nissan due a reset for the VDC on the computer and change pads, and so far i havent seen it happen again thank God cause i was worry that it was a dangerous. When the lights went on the brakes go into abs for safe mode and it doesnt stop normal.. Have them do a reset and check that all pads and rotors are good..Good luck i understand ur frustration...
Flacko is offline
post #9 of 28 Old 11-07-2008, 09:38 AM
BlakSpyda
SHIFT_Moderator
BlakSpyda's Avatar
Quoted: 5 Post(s)
I forgot about that. Have them flash or reset your brake control module. Shouldn't take them anytime at all to do it. That is usually recommended when thr ABS goes out, but it may solve the problem.
post #10 of 28 Old 11-07-2008, 10:58 AM
lhill58
SHIFT_Lurker
Quoted: 0 Post(s)
lhill58 is on a distinguished road
That happen to me few times and then the battery went dead about a month later.
lhill58 is offline
Linear Mode Linear Mode
