HELP. Has anyone hooked up a electric trailer brake controller? - Nissan Armada Forum: Armada & Infiniti QX56 Forums
User Tag List
post #1 of 9 Old 02-19-2009, 05:56 PM Thread Starter
doug rogers
SHIFT_Lurker
Quoted: 0 Post(s)
doug rogers is on a distinguished road
I have the factory tow package.The simple instructions in the manual says to locate the wiring adapter above the parking brake behind lower dash.I can't find squat.Any advice would be appreciated.Thanks
doug rogers is offline
post #2 of 9 Old 02-19-2009, 06:00 PM
Rumplecat
SHIFT_Hardcore
Rumplecat's Avatar
Quoted: 43 Post(s)
Rumplecat is on a distinguished road
Garage
Quote:
To more easily find the adapter all you do is remove the two screws in the lower dash panel and gently pull the top out from left to right. there are just 4 clips holding it in on top and two screws on the bottom. Hope this helps.
James
2004 Armada SE Smoke 4x4, 2 Degree Advanced Timing, Air-Box Mod, K&N Drop In Filter, Active Tuning Grounding Kit, 6000K HID's, LED Interior and Exterior illumination, Chrome OEM Grille, Front Windows Tinted To Mach Back, V8 Emblems, LE Emblem, Big Tow Package, Prodigy Brake Controller, ScanGauge II, Microfilter, Qx56 Chrome Wheels/Steering Wheel, OEM Fog Lights, Back-Up Camera!
1976 Apache Trailer Hard-side Pop Up
Rumplecat is offline
post #3 of 9 Old 02-19-2009, 06:27 PM Thread Starter
doug rogers
SHIFT_Lurker
Quoted: 0 Post(s)
Rumplecat
THANK YOU! Problem solved.I actually had already taken the two screws out on the bottom when I couldn't get access from below but I didn't want to force it loose from the top.However at this point with your input I just yanked the damn thing out and there it was.Took about two seconds.Someone needs to rewrite those instructions in the manual.There is no way I could get to it the way they tell you to.
Doug
post #4 of 9 Old 02-19-2009, 06:55 PM Thread Starter
doug rogers
SHIFT_Lurker
Quoted: 0 Post(s)
Well,that got me access to the trailer brake connector plug,but I still can't find the jumper wire connector that plugs into it.They must have never put it in the vehicle.Off to the dealer tomorrow.
post #5 of 9 Old 02-19-2009, 08:40 PM
Campfamily
SHIFT_Hardcore
Campfamily's Avatar
Quoted: 119 Post(s)
Campfamily is on a distinguished road
Mine was in the rear storage compartment, under the floor. Keep in mind that you will need to splice it to your brake controller harness. You need to know what the various wire colors mean. I know what they are for the 06, but I'm not sure if they are the same for a 09. What brand of controller are you using? If you are using a Tekonsha (Prodigy?), to save yourself the hassle of doing the splicing, you can buy a pre-made harness from them specific to the Armada/Titan. Then, you plug one end in the truck, the other into the controller, and you're good to go. These harnesses are available on the Tekonsha website (www.tekonsha.com).
- 12 Armada Platinum 4WD, Tuscan Sun (red)
- 06 Armada LE 4WD, Red Brawn, QX56 Wheels (traded)
- 04 Armada LE 4WD, Smoke (lemon lawed)
- 15 Ford Focus Electric (commuter car)
- 00 Maxima SE, Manual Trans (kids car)
- 65 Buick Skylark Gran Sport Convertible, 401 ci, 2nd owner, original condition, 70,000 miles (play car)
- Prowler Lynx 826M Travel Trailer, 26', 5000#'s
"How often we fail to realize our good fortune in living in a country where happiness is more than a lack of tragedy."
--Paul Sweeney, author
Campfamily is offline
post #6 of 9 Old 02-19-2009, 09:56 PM Thread Starter
doug rogers
SHIFT_Lurker
Quoted: 0 Post(s)
Campfamily
Thanks for the reply.I have a 2008 Infinity QX and the manual says they taped it under the dash,although it's not there.The trucks I have owned in the past came with the adapters in the glove box etc.Guess I'll find out tomorrow when I go back to the dealer.
post #7 of 9 Old 02-19-2009, 10:07 PM
BlakSpyda
SHIFT_Moderator
BlakSpyda's Avatar
Quoted: 3 Post(s)
Welcome to CA doug rogers!
BlakSpyda is offline
post #8 of 9 Old 02-20-2009, 01:27 PM
Utahrd
SHIFT_Newbie
Utahrd's Avatar
Quoted: 0 Post(s)
Utahrd is on a distinguished road
tekonsha
The simplest, easiest thing is to buy the Tekonsha Prodigy with the plug in adapter.
This dealer will send you the controller, and Harness for Nissan with free 2nd day shipping:
http://www.brakecontroller.com/prodigy1.htm
I saw the tekonsha prodigy without free shipping for $98 at etrailer
Jon
2006 Infiniti Qx56 4x4
2009 Fleetwood Prowler 2702bs #7000 dry, #8000 loaded
2009 Dodge Ram 3500 Megacab 6.7 Liter Cummins Turbo Diesel
Utahrd is offline
post #9 of 9 Old 02-20-2009, 10:57 PM Thread Starter
doug rogers
SHIFT_Lurker
Quoted: 0 Post(s)
Thanks guys.I ended up buying a jumper adapter at my local Nissan dealer.My Infinity dealer is 90 miles away.Hooked it up and everything is great.Don't know why my vehicle didn't come with one.
Linear Mode Linear Mode
