recommended PSI for 305/45/22 - Nissan Armada Forum: Armada & Infiniti QX56 Forums
User Tag List
post #1 of 9 Old 05-13-2009, 12:38 PM Thread Starter
ntrddragn
SHIFT_Hardcore
ntrddragn's Avatar
Quoted: 117 Post(s)
Question recommended PSI for 305/45/22
The tires say 50 Max PSI but what is the correct PSI i should run them at? Right now its at 45. i dont know if i should rum them lower. they look low on and all surface looks to be having contact with the pavement.
'04 LE
ntrddragn is offline
post #2 of 9 Old 05-13-2009, 12:44 PM
Pops
SHIFT_Moderator
Pops's Avatar
Quoted: 40 Post(s)
Garage
I would leave them at 45 if they are riding ok. As long as all surfaces are contacting the pavement and the treadwear is even, I like to keep mine as high as a smooth ride permits.
- Bob
2005 Armada LE 4x4
Pops is offline
post #3 of 9 Old 05-13-2009, 12:52 PM Thread Starter
ntrddragn
SHIFT_Hardcore
ntrddragn's Avatar
Quoted: 117 Post(s)
Cool thanks Pops. the ride is better since i lowered it from 50 to 45. i noticed that at 50 my treadwear isnt even. ill keep them at 45 then. i do noticed tho that since it was wearing out evenly at 50 and now at 45 the steering wheels shakes a little on certain part of the roads. should rebalance them? i just rotate them like almost 3000 miles ago.
'04 LE
post #4 of 9 Old 05-13-2009, 01:03 PM
Pops
SHIFT_Moderator
Pops's Avatar
Quoted: 40 Post(s)
Garage
Yup, rebalance them. Most shops let you pay $60-$75 just one time for lifetime rotation/balancing of the tires for as long as they last. If it's too bouncy over bumps, you might give 40-psi a try, that's where mine are at.
- Bob
2005 Armada LE 4x4
Pops is offline
post #5 of 9 Old 05-13-2009, 03:36 PM
rockendoublez
SHIFT_Hardcore
rockendoublez's Avatar
Quoted: 3 Post(s)
rockendoublez is on a distinguished road
Send a message via AIM to rockendoublez
The tire pressure should be 40-45 psi. Call the tire shop where you got them at. they should be able to tell you exactly what psi it should be for that tire size.
Rockendoublez - Mike
08 Black SE, Kenwood Audio System:
KOSV1000 (carportal)/ KOSL702 (touchscreen) / KNAG510 (Navi) /KCABT200 (BlueTooth), AutoPage GPS / Remote Start, JL Audio Amps/Components/Subs, Eiger Vision HD 10.7" flipdown monitor, E&G Classics Custom Grille, 7" passenger visor monitor, FRONT and Rear night vision cameras
09 Honda Fit Sport w/Navi
06 Acura TL
95 Acura Integra RIP
rockendoublez is offline
post #6 of 9 Old 05-13-2009, 03:38 PM
Pops
SHIFT_Moderator
Pops's Avatar
Quoted: 40 Post(s)
Garage
Quote:
The ones around here will tell you to use the max rated on the sidewall.
- Bob
2005 Armada LE 4x4
Pops is offline
post #7 of 9 Old 05-14-2009, 12:12 PM
9balllrook
SHIFT_Hardcore
9balllrook's Avatar
Quoted: 8 Post(s)
9balllrook is on a distinguished road
When I got my 305/50/20 Yokahama's, they were stamped max 50 psi, the installer put 35 (recommended by Nissan) so I spoke to Yokahama and they told me 38-40 for a vehicle like ours. My suggestion is give your tire manufacturer a call to be safe.
Jerry's 06 SE off road
07+ Intake, Injen CAI, JBA long tubes, Gibson Cat Back, UpRev tuned, 08 caliper kit w/ Frozen/Slotted Rotors, Goodridge Stainless Steel Brake Lines, Stillen 2-row/aluminum Radiator, PML pan, TransGo shift kit, 2" PRG lift, Bilstein 5100s, 20" Fuel Pump w/295/60/20 Terra Graps, 4ga. Grounding Kit, LEDs & HIDs, Kenwood DNX-9960 Alpine PDX amps, Kef separates,
(2) underseat
subs w/Kenwood 10' slims, Twin Stinger Batteries, remote start & protection by Python
9balllrook is offline
post #8 of 9 Old 05-15-2009, 10:29 AM
jcorvair
SHIFT_Enthusiast
jcorvair's Avatar
Quoted: 0 Post(s)
jcorvair is on a distinguished road
Send a message via Skype™ to jcorvair
I would avoid running too close to the max as the pressure will increase when the tires heat up or in hot weather. The higher the pressure the smaller the contact patch with the road as well.
I too would consult the tire manufacturer for their recommendation.
James
'06 Mazda 3 Sport, Gt - Luxury Package (Sunroof, heated leather, etc.)
'05 Sebring
'09 Silverado HD 4x4 Crew Cab, Olympic Vehicle
'65 Corvair Monza 140/4spd
'65 Corvair Corsa Convertible 180/4spd
jcorvair is offline
post #9 of 9 Old 09-14-2009, 11:17 PM
norcal05SE
SHIFT_Hardcore
norcal05SE's Avatar
Quoted: 0 Post(s)
norcal05SE is on a distinguished road
alright, i stole this from a trailer towing forum, but itperfectly explains the "chalk test" for figuring out air pressure. its not scientific but it works. i used it on my jeep wrangler and ran 28psi for 2 years with no problems and the tires wore perfectly! give it a try dude!
1. Put normal operating load on your trailer. 1, 2, or 3 skis, 1 boat...whichever.
2. Inflate tires on both sides to max psi. I say the max psi because this is just a starting ground...you shouldnt need any more than that.
3. Park where you have an open area ahead of you.
4. Mark a thick line across both tires. Only one side is really necessary.
5. Pull forward enough for line on tire to mark the ground.
6. Observe chalk mark on ground, Mark should be of the full tread width. If too narrow, deflate. If it only shows the outside edges, you need to inflate more, BUT you shouldn't need to inflate if you are at the max pressure. You may need to go up in tire size or rating.
7. Deflate accordingly. If you think you need to take a lot out, start at 5 psi increments. Once you start to get close to the full tread, move down to 1 or 2 psi increments. Make sure you deflate both sides the same so the trailer is even!
8. Repeat Steps 4-7. (Remark, Drive, Observe, Deflate)
9. Once even tread contact is observed, Record that air pressure for future use. That pressure will provide the best traction, best wear and be less likely for blowouts.
Matt
norcal05SE is offline
Linear Mode Linear Mode
