VDC-Slip-ABS PLUS 4WD PLUS Brake lights - Nissan Armada Forum: Armada & Infiniti QX56 Forums
User Tag List
post #1 of 14 Old 02-19-2011, 07:10 PM Thread Starter
Kreutz73
SHIFT_Newbie
Quoted: 0 Post(s)
Kreutz73 is on a distinguished road
Yeap... acheived the triple crown today. I woke up this morning and the mada had the VDC-SLIP-ABS lights on... that's strike 1. I've had the mada for 2 years now so I'm used to the various random warning light moods she has so I carried on as normal. Then on the way back from the store the 4WD light popped on and the indcator on the odometer went out (that's strike 2). I was planning on doing the rear brakes today and thought that might help with the first issue anyways so I went ahead and replaced the rear rotors and pads as planned. Took it for a spin and all the lights were still on... 'oh well' I thought. Then I pressed the brakes hard to start the brake in process and voila! strike 3... the brake light came on.
I'm laughing at this point, after all the problems we've all had with the mada and the modules I had to share the story.
I'm hoping the modules just need to be re-flashed or something. The car still drives normal. I'll be taking it in to the stealership tuesday to see what guesses they have.
Just as a further note... lights come on the same way each time. VDC-SLIP-ABS are on right from start up. The 4WD light and vanishing indicator happen about 20 seconds after start-up now every time, i can switch modes normally until the 20 seconds is up. The brake light will only come on if the pedal is pressed hard.
2005 Armada SE 4x4 Black
K2Motor dual halo headlights
17" Pro Comp Extreme flat black rims w/Blizzaks (4 winter)
Kreutz73 is offline
post #2 of 14 Old 02-19-2011, 08:03 PM
97trakin
SHIFT_Hardcore
97trakin's Avatar
Quoted: 8 Post(s)
97trakin is on a distinguished road
How's your brake fluid level? After you did the brakes and the lights were still on did you try pulling the negative battery cable to see if that would reset anything?. It's worth a try I guess. Good luck.
97trakin is offline
post #3 of 14 Old 02-19-2011, 08:29 PM Thread Starter
Kreutz73
SHIFT_Newbie
Quoted: 0 Post(s)
yeah, I played around with things for a bit this afternoon. Before I started the brake job, the fluid was already topped up, it was the first thing I checked when I saw the VDC-SLIP-ABS lights. My rear pads were gone so I actually had to pull out some extra fluid to get down to the max mark after I finished the job.
After my brake job failed to remove any of the lights, I did try taking the battery out, I swapped the relays for 4WD and airbags to see if that would fix the 4WD light aswell and also cleaned the battery terminals and connections and added dielectric grease. None of this helped. Pedal was soft after the brake job and that's when the brake light first came on but soft pedals can be common after installing new pads/rotors so I did go ahead with the brake-in process, it was firm when I parked it for the night... I'm curious to see if it's still firm in the morning... if its still soft I may need to drain and bleed the brake system.
I will definately keep you guys posted.
Kreutz73 is offline
post #4 of 14 Old 02-21-2011, 09:28 AM Thread Starter
Kreutz73
SHIFT_Newbie
Quoted: 0 Post(s)
1 down, 2 to go.
the brake light hasn't come back on since doing a proper burnishing of the new rear brakes.
Might try the 4WD self check today and check/clean a couple body grounds.
has anyone ever had the ABS/SLIP/VDC light on with the 4WD lamp at the same time?
Kreutz73 is offline
post #5 of 14 Old 02-21-2011, 12:28 PM
xdepp043
SHIFT_Lurker
Quoted: 0 Post(s)
xdepp043 is on a distinguished road
same problem here
Hi, I've got the same problem with my 04, simply replaced a dead battery and all the lights came, have tryed all suggestions given here with no results, will probably have to take it to dealer to fix unless someone comes up with an answer to it, did have the ECM replaced no more then a week ago, still have lights on, good luck with yours
xdepp043 is offline
post #6 of 14 Old 02-21-2011, 03:29 PM Thread Starter
Kreutz73
SHIFT_Newbie
Quoted: 0 Post(s)
4WD light self diagnostic doesn't want to work for me. In the service manual instructions it asks to switch the 4WD switch and AT lever in a certain order. It doesn't specify how long to wait at each step... it also asks to switch the 4WD switch from auto to lock, do they mean 4H or LO is lock?
Kreutz73 is offline
post #7 of 14 Old 02-21-2011, 03:30 PM Thread Starter
Kreutz73
SHIFT_Newbie
Quoted: 0 Post(s)
4WD diagnostic without consultII
here's the service manual proceedure....
1. Warm up engine.
2. Move A/T selector lever to “P” position.
3. Turn 4WD shift switch to “2WD” position.
4. Turn ignition switch “ON” and “OFF” at least twice, and then turn ignition switch “OFF”.
5. Turn 4WD shift switch to “AUTO” position.
6. Turn ignition switch “ON”. (Do not start engine.)
7. 4WD warning lamp ON.
If 4WD warning lamp does not turn ON, refer to TF-122, "4WD Warning Lamp Does Not Turn ON" .
8. Move A/T selector lever to “R” position.
9. Turn 4WD shift switch to “2WD”, “AUTO” and “2WD” in order.
10. Move A/T selector lever to “D” position.
11. Turn 4WD shift switch to “LOCK”, “AUTO” and “LOCK” in order.
12. Move A/T selector lever to “N” position.
13. Turn 4WD shift switch to “AUTO” position.
14. Move A/T selector lever to “P” position.
15. Read the flickering of 4WD warning lamp.
the manual actually says step 1 is warN up the engine but I assume they meant warM.
Kreutz73 is offline
post #8 of 14 Old 02-22-2011, 09:28 PM Thread Starter
Kreutz73
SHIFT_Newbie
Quoted: 0 Post(s)
follow up as promissed.... went to dealership today and tech said "pages" of codes came out, some he wrote down for me were:
C1142 (pressure sensor), C1109 (batt voltage abnormal), U1000 (cann com circuit), P1808 (speed sensor), O1803 (abs op sig), P1831 (vdc op sig), P1827(clutch pressure), P1828 (line pressure), B2573 (batt voltage)... after he cleared them the ABS, VDC, and speed sigs returned.
They recommended replacing the front left hub/sensor and starting there indicating more problems may be likely.
Brought the car home to look at it myself and sure enough there was a knick in the wire of the front left abs sensor (not sure why they didn't find this but recommended replacing the entire sensor - parts replacers!!) there was visible corrosion on the wire.
I cleaned and soldered the wire and took it for a spin, all is good for now. Need to get a replacement wire for the sensor... good news is that its on the ECU side, not the sensor side, so it should have plugs on both ends.
I also swapped out the battery connector with a solid lead one. I swear the voltmeter in the car reads higher now.
Because I've had the more common unexpected brake failure a number of times over the past couple years I asked them to check for the TSB that covered it (NTB06-040) but they couldn't find it the right TSB to reference even though I gave them the number.... go figure.
Kreutz73 is offline
post #9 of 14 Old 02-25-2011, 07:13 AM
schulzie
SHIFT_Lurker
Quoted: 0 Post(s)
schulzie is on a distinguished road
I had the VDC/Brake/Slip light come on on my 05 2WD. Took it to dealer, since I have extended warrenty. They called back, said it was due to the front brakes being worn. I didn't really believe that, but seeing as how I was getting divorced and moving out that day, I didn't have the time to mess with it, and I was going to pay for the inspection anyways. They replaced the front pads, turned the rotors, and flushed the fluid. Guess what, lights still on. So after that $500 bill, it still wasn't right. Then they did the diagnostics, found a bad sensor in the brake fluid line. They changed both of them (Code C1142, Pressure sensor circuit, 2 P/N 47240-7S000, Sensor assy, HYP, unit price 148.52) that cleared it. I had them save the brake pads for me. They were only half worn, not real happy about that. Ended up sitting down with service manager, finally agreed on pads at cost, paid for fluid flush, and labor at employee rate. Plus an oil change. I guess thats fair, but I did inform them that their order of troubleshooting was lacking, as a half worn pad should not cause those problems. The sensors were done under warrenty. Hope that helps out
schulzie is offline
post #10 of 14 Old 02-26-2011, 08:30 PM
kh971
SHIFT_Lurker
Quoted: 0 Post(s)
kh971 is on a distinguished road
I have the same lights on and my dealer wants to replace the seatbelt sensor since inertia would cause these lights come on.
kh971 is offline
Linear Mode Linear Mode
