Changed A/T Fluid - Nissan Armada Forum: Armada & Infiniti QX56 Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Nissan Armada Forum: Armada & Infiniti QX56 Forums > Armada Technical Discussions > Engine/Drivetrain
  #1
Old 04-11-2011, 06:42 PM
scr38's Avatar
scr38 scr38 is online now
SHIFT_Administrator
scr38 is on a distinguished road
Changed A/T Fluid
Today I did an engine oil and filter change and drained and refilled the transmission.
The transmission fluid, which was Amsoil, had 38K miles on it and looked and smelled like new fluid. It was bright red with no burned smell at all. Since I have the PML pan, it took 9 quarts of Amsoil to refill after the drain. I also inspected the differential lube, which is Amsoil 75W140 Severe Gear Lube (synthetic). It looked just as it came out of the bottle; clean golden color.
I'm sure it wasn't necessary to change the A/T fluid since it looked so good, but it can't hurt!
  #2
Old 04-11-2011, 06:57 PM
scot0410's Avatar
scot0410 scot0410 is offline
SHIFT_Hardcore
scot0410 is on a distinguished road
Good to hear that the fluids still looked great. You are right. It can't hurt and makes you feel better knowing the new fluid is in.
__________________
06 SE 4WD Red Brawn, Leather, Tow Package, 2* timing, Borla dual exhaust, Injen cai, 4300k hid, Hyper Grounding Wire, Bilstein 5100s, PRG Mini Lift, Fumoto Oil Drain Valve, Second row bench changed to captains chairs and Console,Hunter Bull Bar, Nitto Terra Grappler 325/60/18.
  #3
Old 04-11-2011, 07:03 PM
RC340's Avatar
RC340 RC340 is offline
SHIFT_Hardcore
RC340 is on a distinguished road
a little TLC goes a LONG way, it pays off in the long run
  #4
Old 01-04-2013, 12:25 PM
tomf tomf is offline
SHIFT_Lurker
tomf is on a distinguished road
SCR38 when you originally switched to Amsoil did you just do a drain and fill or did you drain from the cooler line and get all of the jmatic fluid out ? I wanted to put in Amsoil, but wanted to just drain the pan and add the 4.5 quarts of amsoil and then do that a couple of more times within the next couple of months. Is it ok to mix amsoil with the Nissan S fluid ?
thanks
  #5
Old 01-04-2013, 03:30 PM
scr38's Avatar
SHIFT_Administrator
I did just what you plan to do. The fluids mix fine. After a couple more changes it will be almost pure Amsoil.
I now how 115K miles on my Armada, and the transmission, engine and differential are all like new; all using Amsoil.
  #6
Old 01-07-2013, 12:15 PM
SHIFT_Lurker
SCR38 - thanks for the quick reply ! I just did a drain and fill yesterday and put the amsoil in. I drove it around for 15 minutes or so and did notice that it runs cooler than the nissan s fluid. I need to drive around more and get the fluid warmer to see if it still has a shudder into 3rd gear. I will report back later this week when I drive it again.
  #7
Old 01-21-2013, 12:39 AM
E&J push'n wind E&J push'n wind is offline
SHIFT_Hardcore
E&J push'n wind is on a distinguished road
scr38,
Curious, if anybody knows I'm sure it's you! Do you know if the rear diff cover from the Nissan Pathfinder is a direct fit for the Armada. I wonder why nissan saw fit to put a finned diff cover on the Pathi but not on the Mada, strange!
Powered by vBulletin®
© AutoGuide
