2004 Armada Stalls still after Relay has been replaced - Nissan Armada Forum: Armada & Infiniti QX56 Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
  #1
Old 05-31-2011, 08:49 PM
mpdecrow mpdecrow is offline
SHIFT_Lurker
mpdecrow is on a distinguished road
I have a 2004 Nissan Armada that just stalls with no warning. It happens at idle, accelerating or when applying my brakes. I have had the relay replaced because of the recall, it still does it. The technicians put it on the diagnostics machine and there was no errors. They are stumped and are thinking it might be the fuel filter. They are not sure. Any thoughts?
  #2
Old 05-31-2011, 09:39 PM
TitanBlue TitanBlue is offline
SHIFT_Enthusiast
TitanBlue is on a distinguished road
Usually the Fuel Pump/Filter/Sensor Assembly. Common issue.
Did you have a recent recall on the Sensor Assembly? (It includes the whole thing if I recall correctly, I may be wrong).
  #3
Old 05-31-2011, 10:09 PM
BlakSpyda's Avatar
BlakSpyda BlakSpyda is offline
SHIFT_Moderator
Welcome to CA mpdecrow!
TitanBlue's suggestion may be your culprit.
  #4
Old 06-01-2011, 01:40 AM
chrisarmada chrisarmada is offline
SHIFT_Enthusiast
chrisarmada is on a distinguished road
Did it stall before the relay change recall? It is rare but they could have put in a defective one. I wonder if there is a similar one you could swap out just for the heck of it.
__________________
Chrisarmada
04 SE Gray, 05 dark gray wheels, K/N drop in, airbox mod, BFG AT's, 6000K HID, EBC Greenstuff, yellow calipers, powerslot rotors, Goodrich ss lines, 3000K HID fogs, LED everything, Bilstien HD's, foam filled sway bar, urethane bushings, 2 degree mod
  #5
Old 06-01-2011, 03:21 PM
RC340's Avatar
RC340 RC340 is offline
SHIFT_Hardcore
RC340 is on a distinguished road
welcome to CA dont think 04 are part of the fuel recall, think you can swap out fog light relay in the box
  #6
Old 06-01-2011, 05:53 PM
SHIFT_Lurker
Update: the dealer dumped 20 gallons of fuel to pull the fuel assembly. Nothing wrong there. They sent it home with a technician to see if they can better determine when the stalls happen. My bill sat $500.00 and they don't have a fix. Grrr. Any more ideas? Yes te car started stalling before they replaced the relay.
  #7
Old 06-01-2011, 06:45 PM
SHIFT_Enthusiast
They will need to check Fuel Pressure at start up, and while running to see if it falls off just prior to stalling or whatever. I would expect the tech has taken his "Consult" computer with him to do such testing. He'll be able to monitor everything.
  #8
Old 06-03-2011, 01:43 PM
SHIFT_Lurker
Camshaft position sensor
It turns out that if finally throw a code while stalling out. They are now replacing the camshaft position sensor. I hope this fixes the problem.
  #9
Old 11-17-2012, 03:33 PM
Cookieman626 Cookieman626 is offline
SHIFT_Lurker
Cookieman626 is on a distinguished road
I had the same stalling issue and replaced the ECM Relay as the forum members suggested. Nearly ponied up for the $400 IPDM but decided to drop it off to my buddy's shop. By some stroke of luck, it FINALLY threw an engine code for the Cam Position Sensor. Mind you, I've been dealing with the stall issue for over 600 miles with no engine light. $40 bucks plus labor and I'm back on the road.
Powered by vBulletin®
© AutoGuide
