I just had mine replaced a month ago. If I were you, I would not put in another OEM, unless they are doing it under warranty.
Instead... look at getting a Koyo ($205) and my Nissan dealer charged me $130 labor to replace it. I provided them with the coolant and the cap. Otherwise they charge something like $25 a gallon if they use their coolant. Note that the Koyo does not come with a cap. I went to my local parts place and got a Stant cap. Again, the OEM cap is known to be problematic.
Koyo site search: http://www.koyorad.com/search.asp
I actually bought mine through autopartswarehouse. For some reason they don't list anything for an '04... but you could probably call them and work it out. Anyway, here's the link: http://tinyurl.com/ctwnv45
The spring-type hose clamps are also known to be weak points in the cooling system, and you should consider replacing those with worm-gear type clamps instead.
How much are they charging you for the radiator? At about 2 hours labor ($150 at my shop) they must replacing not only the radiator and coolant but also the hoses,clamps, a belt and a tensioner!
At those prices they should change your oil, rotate your tires,wash & wax and fill up your tank!
Tell them that is way too much and have the service manager go over the estimate with you and explain everything that they are doing. Do it now!
They are charging about $600 for the OEM Nissan radiator, $50 for coolant, clamps plus $360 labor. I talked to a manager who said he does not recommend aftermarket parts, but he said they can install a get a radiator for $205 but the labor will still cost the same.
I said thank you and cancel their order - looking for a local shop that can replace it cheaper. Thanks for your help guys!
__________________
2004 Nissan Armada LE
80K miles
Minneapolis, MN, USA.
verakot, the dealer is gouging you! GO GET YOUR MONEY BACK!
The average cost to replace a radiator in MN is about $700. Below is the price I calculated for St. Paul.
$715.46
Parts (78%) Labor (22%)
Estimate Details
Radiator Replacement for 2006 Nissan Armada
Parts (78% of total cost)
Cooling System Parts: # 21460ZQ00A x 1 $555.46 Parts: #Oil/Fluid Prices not included$0.00
Labor (22% of total cost)
Installing Cooling System $80.00 per hour x 2.0 hours $160.00 Using standard rate at ZIP 55104. Customize Labor Rate http://www.driverside.com/car-repair...style_id=31714
