05 armada overheating - Nissan Armada Forum: Armada & Infiniti QX56 Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
  #1
Old 06-04-2012, 09:49 PM
fastrthnstock fastrthnstock is offline
SHIFT_Lurker
fastrthnstock is on a distinguished road
05 nissan armada overheating... while driving on the highway with the a/c on it runs great... when i come to a red light or traffic slows it starts to overheat never fails so i turn a/c off and switch to full heat and it returns to operating temp after about 15 secs but only for 10 to 15 mins even with the heater on then it overheats again, once it overheats with the heater on it starts to blow neutral air not hot not cold and my tranny starts to slip... i replaced radiator months before problem... since ive had this issue ive replaced, fan clucth, aux fan, thermostat and rad cap... not sure but i think the water pump is ok as i can see water flowing in the radiator... Please help
  #2
Old 06-05-2012, 09:46 AM
BlakSpyda's Avatar
BlakSpyda BlakSpyda is offline
SHIFT_Moderator
Welcome fastrthnstock!
Based on what you described, I would have said thermostata also, but you already repleced it. Maybe it is your radiator or something is clogging up a hose.
  #3
Old 06-05-2012, 02:06 PM
nyc2005armada's Avatar
nyc2005armada nyc2005armada is offline
SHIFT_Hardcore
nyc2005armada is on a distinguished road
Change out your radiator, it is clogged, some reason the regular OEM type with the plastic tops and bottoms tend to clog, bite the bullet and put in an all aluminum one.
__________________
2005 Smoke LE 4X4,
[SIZE=]Uprev tuned, Injen CAI, 2 degree advance, debaged, 5000K Head light and 6000K Fog HID's, 50 series flowmaster with 3inch chrome exit. [/SIZE]
  #4
Old 06-05-2012, 03:51 PM
gt-leo gt-leo is offline
SHIFT_Enthusiast
Can be clogged! But!
Ok so if your coolant fluid level on the high mark. Using the reservoir. To me it sounds like there isn't much coolant in there since you mentioned about the heater stop working. When you fill it up make sure you hotly check the radiator but the reservoir as well. It's not a normal overflow reservoir like opmost cars have. If thermostat isn't opening you wouldn't see the flow through the radiator like you mentioned.
  #5
Old 06-13-2012, 04:10 PM
bigtruck bigtruck is offline
SHIFT_Lurker
bigtruck is on a distinguished road
Overheating on low trafic and A/C
You are describing exactly the problem with my 2007 Armada SE. She has 34000 miles. Someone told me that the problem is that air bubbles in the system that remained after any repair. I do not know how I can purge it. If someone can tell me how, we could try to fix it. Thank you.
  #6
Old 12-07-2012, 05:48 PM
SHIFT_Lurker
I cant fix overheating problem. Please help me.
Sent from my SGH-I897 using AutoGuide.Com Free App
  #7
Old 12-07-2012, 06:10 PM
Pops's Avatar
Pops Pops is offline
SHIFT_Moderator
Garage
You should be able to just top off the radiator. By nature air bubbles travel to the highest poisition in the system, which is the radiator fill nozzle.
__________________
- Bob
2005 Armada LE 4x4
  #8
Old 12-07-2012, 07:06 PM
mspeedrider@aol.com mspeedrider@aol.com is offline
SHIFT_Lurker
mspeedrider@aol.com is on a distinguished road
help power pup
New to the form need some help got a 04 Nissan armada 4x4 and just got a power pup will it work on my year of truck
  #9
Old 12-10-2012, 01:16 AM
Kooshtaka's Avatar
SHIFT_Hardcore
Quote:
Welcome to the Club. Be sure to participate in the Ride of the Month (ROTM) threads.
Sent from my SAMSUNG-SGH-I727 using AutoGuide.Com Free App
__________________
  #10
Old 12-10-2012, 10:18 AM
Boland01 Boland01 is offline
SHIFT_Newbie
Boland01 is on a distinguished road
Had this the same problem with our 05 LE 2-1/2 years ago. Changed out the thermostat and had the Nissan dealer bleed the system. Still no change. Solved the problem by buying a new radiator (Koyo) and putting it in myself.
After that we have had zero issues. Turns out the original oem radiator was pretty clogged up internally.
Powered by vBulletin®
© AutoGuide
