Headers bolts to Block - Nissan Armada Forum: Armada & Infiniti QX56 Forums
User Tag List
post #1 of 8 Old 11-20-2012, 06:25 PM Thread Starter
indresda
SHIFT_Enthusiast
indresda's Avatar
Quoted: 0 Post(s)
indresda is on a distinguished road
Send a message via MSN to indresda
Ok, So i was able to remove the stud from the block. I found it was stripped on the block and the tread on the stud is completly damaged. The dealer changed both my cracked headers several years back. What can i do? I bought new stud, should i just force the stud on the block? or re-tread? what size tread? Damm this is becoming a nightmare!
Eclipse 5495 30 G HDD, Eclipse rear camera, D6's front & passenger, JL 300/4, JL 500/1, JL W6 H/O Box,2 Headset Myron & Davis, Myron & Davis flip down,
4 way audio/Video switcher w/TV tuner , DVD, Xbox 360, Sirius satellite. Nitto Dune Grappler DT, Chrome Pilars, Stainless Steels door seals, Stainless steel Gauge, Tuele Stealth box w/ Rack Extender, Magna Flow Performance, Volant cool air intake, Active tunning kit
indresda is offline
post #2 of 8 Old 11-20-2012, 08:11 PM
Kooshtaka
SHIFT_Hardcore
Kooshtaka's Avatar
Quoted: 102 Post(s)
Ouch indresda! I wish I could be more helpful... maybe PM Pops or scr38? nyc2005armada I think might be able to give you more info also...
'05 Mada LE Slate
Mods Done: UpRev, Bilstein 5100s in front, PRG 2" rear spaces, R1 Premium Drilled & Slotted Rotors, PosiQuite pads, Volant GenII CAI, 8K HID Lows, LEDs by ArmaDen, 3k HID Fogs, and Delete middle row console.
Mods in progress: JBA LT, PRT 300-cell hi-flo cat'd b-pipes, Borla xlr-1 muffler w/custom tubing, LED Engine Bay LEDs, Custom Suspension Lift by PRG, Custom PRG front & rear shocks, Custom PRG Rear springs.
Mods in contemplation: GoodHood or custom hood, Steel front and rear bumpers, upgraded front springs, Custom roof rack and cargo basket, Additional lighting.
Kooshtaka is offline
post #3 of 8 Old 11-20-2012, 09:14 PM Thread Starter
indresda
SHIFT_Enthusiast
indresda's Avatar
Quoted: 0 Post(s)
thanks bro. I called Folsom Nissan and told them that the studs on the block are trashed, since they were the last people to touch my car by replacing my cracked header..They just recommend a machine shop. Not happy but what can i do, i need my Armada...yeah it sucks. But i bought new studs and screwed them up into the block..oh well!
indresda is offline
post #4 of 8 Old 11-20-2012, 09:20 PM
ntrddragn
SHIFT_Hardcore
ntrddragn's Avatar
Quoted: 117 Post(s)
i would not force the new bolt in there. if you are going the 'retreading' route, you will want to get the tap that is slightly bigger then hole right now. make sure the tap is straight when you first start the tap and spin it slowly. one or two full cycle then reverse it out, this helps to break loose the metal chips, then tap it back in to the place you stop before and do another 1 or 2 full turn and repeat. and remember to oil the tap as you go this helps with the process and the metal chips. like kooshtake said hit up the others members. hopefully they can offer other alternatives.
'04 LE
ntrddragn is offline
post #5 of 8 Old 11-20-2012, 10:03 PM
Pops
SHIFT_Moderator
Pops's Avatar
Quoted: 40 Post(s)
Garage
I would use a wire pipe cleaner to clean the threads really good first, and use some anti-sieze. If that still doesn't work then I would consider re-tapping. Just remember the tap needs to match whatever new bolt you're using for that hole.
- Bob
2005 Armada LE 4x4
Pops is offline
post #6 of 8 Old 11-21-2012, 07:57 AM
rsoto80
SHIFT_Hardcore
rsoto80's Avatar
Quoted: 15 Post(s)
rsoto80 is on a distinguished road
You will need to re-tap the threads like everyone said. The problem is you have to use a bigger stud and different nut to hold the header down..take your time as the cylinder head have little room for error. Good luck.
04 Nissan Armada all stock
06 Dodge Charger R/T
13.8@101mph
rsoto80 is offline
post #7 of 8 Old 11-21-2012, 01:53 PM Thread Starter
indresda
SHIFT_Enthusiast
indresda's Avatar
Quoted: 0 Post(s)
thnk you, guys. its done. :0 Does anyone know the torque on the headers bolt?
indresda is offline
post #8 of 8 Old 11-21-2012, 02:16 PM
Kooshtaka
SHIFT_Hardcore
Kooshtaka's Avatar
Quoted: 102 Post(s)
i think they are supposed to be 22 ft lbs
'05 Mada LE Slate
Linear Mode Linear Mode
