Airbags work intermittently - Nissan Armada Forum: Armada & Infiniti QX56 Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Nissan Armada Forum: Armada & Infiniti QX56 Forums > Armada Technical Discussions > Suspension/Tires/Brakes
  #1
Old 11-25-2012, 12:56 AM
dan-imal's Avatar
dan-imal dan-imal is offline
SHIFT_Enthusiast
dan-imal is on a distinguished road
Question Airbags work intermittently
Can someone help me figure out why the compressor kicks on when it feels like it? The relays everyone suggests swapping, they're brown/tan and labeled 25230, right? I swapped the two and I'm getting the same results. When the compressor works the airbags inflate and things are good. This problem happens with lighter and heavier loads and it's a pretty recent issue.
Any ideas on what the problem is or what to check?
Thanks,
Dan
__________________
2005 Armada LE 4x4 Nav - 15MPG - $26/100M
2012 Chevy Volt! Shocking huh? Averaging $5/100 miles ($4 electricity & $1 gas /100m)
April '12 1,100 miles on 2 gallons of gas and $42/month of electricity
May 17th '12 2,600 miles on 5 gallons of gas and $42/month in juice
June 10th '12 3,700 miles on 7 gallons of gas and $43/month in electricity
  #2
Old 11-25-2012, 07:23 AM
scr38's Avatar
scr38 scr38 is online now
SHIFT_Administrator
scr38 is on a distinguished road
Check the system for leaks. Mix up a little dish washing soap and water, and use the solution to check the air line connections for bubbles. There have been problems with the O rings leaking at air line connections.
  #3
Old 11-25-2012, 09:12 AM
dan-imal's Avatar
SHIFT_Enthusiast
Quote:
Thanks for the idea, I'm sure there are leaks but I don't think that's what's causing my intermittent issue. Here's why: I can put a seriously heavy load on the hitch, watch the truck squat and get nothing from the compressor. I can let the truck sit (engine off) with the weight on the hitch, come back and start the engine (wait 3-5 min) and the compressor still won't kick on. And then there's times when it will kick back on.
And, when it works, the system works great. The compressor isn't running constantly (or a lot) like it would with a faster leak that was overheating the compressor (just MHO).
So, I don't think it's a leak that's causing the problem, but if you're sure that it is I'll look into it. Either way I'm sure the O-rings could use replacing at some point but I don't know if it's my main issue.
Thank you,
Dan
__________________
  #4
Old 11-29-2012, 11:20 AM
docpaulo docpaulo is offline
SHIFT_Newbie
docpaulo is on a distinguished road
compressor
I had the same problem... luckily was covered by my extended warranty so it only cost 50$...
there was a leak in the system... this caused the compressor to never reach a steady state and eventually burn out...
the compressor overheats then stops working until it recovers, thus the intermittent function...
the busted compressor is what damaged the relay as that was replaced too...
basically the compressor reached the set height, the leak makes it go down so several times during the trip, the compressor is going on and off...
compressor is about 300$ or so... but you need to fix the leak first or your new compressor will go bust too...
hope this helps
Powered by vBulletin®
© AutoGuide
