need some suggestions on mada strut being stuck - Nissan Armada Forum: Armada & Infiniti QX56 Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Nissan Armada Forum: Armada & Infiniti QX56 Forums > Armada Technical Discussions > Suspension/Tires/Brakes
  #1
Old 11-27-2012, 06:54 PM
Cash2005 Cash2005 is offline
SHIFT_Lurker
Cash2005 is on a distinguished road
Hi,
Ive got my 2005 mada up on jacks atm. I am following this thread on removal and installation. http://www.clubarmada.com/forums/showthread.php?t=17919
I have the 3 bolts off and the lower nut and bolt and have tried to lever it out with a 2x4 but it aint budging on the lower part of the strut where the big nut and bolt connects to the lower arm assembly. I can see the 3 bolts on the top moving down when I apply leverage but it only goes so far.
Any suggestions on what I may be doing wrong?
edit. I have only one side jacked up. I just read something about a swaybar and both side need to be raised. But odd thing is, I tried hammering the lower strut to realign the holes in case I have to put it back together and it wont even budge even a 1/32"
  #2
Old 11-27-2012, 07:00 PM
ntrddragn's Avatar
SHIFT_Hardcore
I just pushed down in the lower arm and have someone else tap it out.
__________________
'04 LE
  #3
Old 11-27-2012, 08:36 PM
Kooshtaka's Avatar
SHIFT_Hardcore
What I did was stand on the 2x4 while my friend simply removed the coil over... no banging necessary... did you unhook all the abs wires? completely remove top nuts and bottom bolt?
__________________
  #4
Old 11-27-2012, 09:47 PM
ntrddragn's Avatar
SHIFT_Hardcore
Quote:
I like to bang things. Its a man thing. LOL
__________________
'04 LE
  #5
Old 11-28-2012, 01:42 AM
SHIFT_Lurker
Hi, thanks guys.
I had to put it all back together so I could drive somewhere.
But I think ive got it figured out now. Its alot easier when my wife was here to help me leverage the 2x4 and then I could move the lower strut end.
I did not touch any wires or hoses.
I like my hammers too
  #6
Old 11-28-2012, 02:29 AM
Kooshtaka's Avatar
SHIFT_Hardcore
lol that's what she said
Sent from my SAMSUNG-SGH-I727 using AutoGuide.Com Free App
__________________
  #7
Old 11-28-2012, 11:12 AM
Pops's Avatar
Pops Pops is offline
SHIFT_Moderator
Garage
Here: http://www.clubarmada.com/forums/showthread.php?t=8988
You need to disconnect the sway bar on at least one side or you'll never get that LCA low enough to remove the shock.
__________________
- Bob
2005 Armada LE 4x4
  #8
Old 11-28-2012, 11:43 AM
drewcs drewcs is offline
SHIFT_Hardcore
drewcs is on a distinguished road
I agree with Pops. Piece of cake once you disconnect the sway bar.
__________________
'06 LE, 20" Titan wheels w/Cooper ATP's, Full LED conversion, 4300K HID low beams, Bilstein HD, R1Concepts Premium drilled/slotted w/posi ceramics. Airaid MXP CAI w/dry filter. BullyDog GT Performance Tune.
  #9
Old 11-28-2012, 12:04 PM
Kooshtaka's Avatar
SHIFT_Hardcore
It worked fine for me using the a long bit of 2x4 and using that to lever the lower control arm down... didn't disconnect the sway bar. getting the 5100s in at the highest setting was a bit fun though. haha.
__________________
  #10
Old 11-28-2012, 05:27 PM
RocketPower RocketPower is offline
SHIFT_Lurker
RocketPower is on a distinguished road
I did it without taking off the sway bar, and you don't need a 2x4. What we did was to jack up the front two wheels so there is no tension on the sway bar. To get the extra clearance to get the strut out, just open the hood (so there is something to hold on to), and then have a friend stand on the rotor and push it down. It doesn't require a whole lot of extra clearance to get it off. The same applies when putting the new strut in. As always the first side takes much longer than the other. Have fun.
Powered by vBulletin®
© AutoGuide
