Steering Shimmy / Shake over Bumps - Nissan Armada Forum: Armada & Infiniti QX56 Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
  #1
Old 12-07-2012, 07:53 AM
emower419 emower419 is offline
SHIFT_Lurker
emower419 is on a distinguished road
Before I start into this project to correct I wanted to get some input and areas of known concern on these Titan / Armada Front ends.
Problem:
Over sharp bumps, potholes, rail road tracks, ect... I get a pretty sevear shimmy through the steering wheel.
I'm not so sure it is bad shocks because I don't have any other problems with a bouncy front end. To make it worse my drivers door rattle (bangs against the door jam at the top rear corner when the steering shimmys. Since this truck uses a Rack instead of Old School crappy Steering I don't see a need for a stablizer but it sure feels like it could use one.
Any ideas?
  #2
Old 12-07-2012, 10:36 AM
ntrddragn's Avatar
SHIFT_Hardcore
bump steer..replace the front shocks with either bilstein HD or 5100. difference 5100 are height adjustable.
__________________
'04 LE
  #3
Old 12-07-2012, 01:22 PM
Kooshtaka's Avatar
SHIFT_Hardcore
also make sure tires properly inflated.
__________________
  #4
Old 12-07-2012, 03:47 PM
steveg_nh steveg_nh is offline
SHIFT_Hardcore
steveg_nh is on a distinguished road
I also thought it was bump steer on mine, but the dealer, under an extended warranty, replaced a bad tie rod and the sway bar bushings, and it was like a new truck again.
__________________
2008 Armada SE 4x4 w/Leather, Comfort & Conv. Package, M&D DVD System
  #5
Old 12-08-2012, 06:53 AM
blackArmada_Dxb's Avatar
blackArmada_Dxb blackArmada_Dxb is offline
SHIFT_Hardcore
blackArmada_Dxb is on a distinguished road
Most probably you need new shocks, but sometimes a full 4 wheel drive alignment can also help.
  #6
Old 12-08-2012, 12:57 PM
primoV8's Avatar
primoV8 primoV8 is offline
SHIFT_Hardcore
primoV8 is on a distinguished road
Send a message via AIM to primoV8
Any vehicle with the modern macpherson strut setup like our armadas will always have some type of bump steer. The reason why this happens is because the ends of the steering arms move in a different arc/angle than the wheels when the suspension has to move up or down. Even worse when its a poorly designed suspension geometry mated with a poor set of shocks as what Nissan has done with our trucks.
Although bump steer cannot be eliminated with simple bolt-ons, these simple modifications can be done to lessen the effect. Simple mods such as upgrading the front shocks (i.e. Bilstein, Rancho XLs). Even if you stiffen up the front end by eliminating all rubber bushings, eyelets, etc. and replace them with urethane (i.e. Energy Suspension, Prothane) to reduce suspension travel, too stiff of a ride will have its own issues as well.
There are extreme measures that can be done to the suspension system but unless you plan on autocrossing with the armada, stick with the upgraded shocks and a proper 4-wheel alignment.
__________________
2004 LE
FX-R V.2 Bi-xenon Projector Retrofit
Philips Ultinon D2S 6K bulbs - Philips Ballasts
FX-R V.1 Bi-xenon projector "FOG" Retrofit
TRS D2S 3K bulbs - TRS Ballasts
SMD-LED Int/Ext via ArmaDen
JBA Evol SS Catback
PRT B-pipes 300 cell
Volant CAI
2* Timing Advance
2011 MB GL550
D1S 6K bulbs
2012 Audi A5
D3S 6K bulbs
  #7
Old 12-08-2012, 03:32 PM
08ArmadaSE's Avatar
08ArmadaSE 08ArmadaSE is offline
SHIFT_Enthusiast
08ArmadaSE is on a distinguished road
Quote:
Originally Posted by primoV8 View Post
unless you plan on autocrossing with the armada, .
Hmmm.... I wonder....
Sent from my SCH-I500 using AutoGuide.Com Free App
__________________
2008 Armada SE
No Mods as of yet. Wife doesnt want anything done to it but we will see.
2010 Titan Pro-4x:
Maganflow DISO muffler with JBA tip. Factory matched window tint. Tinted tailights, Debadged. Volant Powercore intake.
  #8
Old 12-09-2012, 10:11 AM
SHIFT_Lurker
Thanks for everyone's input. I have narrowed it down to the right front corner. That side seems to be affected most when running over bumps and such. It's a rainy day today so I won't be digging into it this weekend but I will update when I figure out what is wrong.
  #9
Old 04-14-2013, 04:30 PM
SHIFT_Lurker
I did install new shocks a while back. There was some inital inprovement. But, After Driving a few thousand miles and over some rough ground, it's still there. The sway bar bushings looks shot. I'm going to do those next. Front tires are cupping on the inside. So I'm thinking alignment might be the other factor. I"m also going to be fixing up the rear suspension as it is very harsh also.
Powered by vBulletin®
© AutoGuide
