Intermittant Starting Issue - seems like battery, but it tests fine. - Nissan Armada Forum: Armada & Infiniti QX56 Forums
User Tag List
post #1 of 12 Old 01-17-2013, 04:43 PM Thread Starter
NHand
SHIFT_Lurker
Quoted: 1 Post(s)
NHand is on a distinguished road
For about 6 months, I have been having this problem and recently it has gotten worse. My car just won't start - seems like the battery - we jump it and it starts fine. Battery has tested fine, Alternator has tested fine.
Here is the situation for the first time it happened to me. I was at the car wash and I kept the car on Acc. so that my kids could watch a DVD. I washed the car for maybe 10 minutes. When I got back in, it was completely dead and we needed a jump. My friend came in a Dodge Ram and it took quite a bit to gain enough charge for it to start. I didn't have anything tested after this time because I assumed I had run the battery down, but it certainly doesn't seem like it should be dead after only 10 minutes or less on acc.
Now, I just got my car back from a body shop. They told me that they had to jump it 3 times while there. I'm sure they probably had the hood up and doors open and such, so I imagine interior lights were on, but again it doesn't seem like that should have been enough to drain the battery. The body shop told me that the last time they jumped it that the battery smoked. ???
So, I had the battery tested by two places and it tested fine - the alternator also tested fine (though, I didn't feel that was the issue anyway).
I have never tested the voltage in the battery when this issue occurs.
Any ideas??
Side note - my car has issues "seeing" the Key Fob pretty regularly - could the two be linked in some way??
NHand is offline
post #2 of 12 Old 01-17-2013, 04:51 PM
Pops
SHIFT_Moderator
Pops's Avatar
Quoted: 40 Post(s)
Garage
It's most likely the battery, just replace it... FWIW, I picked up the one from Wal-Mart back in '06 I think, it has a free unconditional replacement for 3 yrs, the reason I got it is because Wal-Mart is nationwide and easy to find a 24/7 store. The battery NEVER lasts even 2yrs, I think I had one last 2-yrs to the day, so anytime mine starts acting up, I just pull into Wal-mart pull my little open-wrench set out of the back, pop the hood, pull it out, carry it inside, swap it, then install the new one. I'm usually done and back on the road in 20-mins tops and it saves all the headache you're going through.
- Bob
2005 Armada LE 4x4
Pops is offline
post #3 of 12 Old 01-17-2013, 05:15 PM Thread Starter
NHand
SHIFT_Lurker
Quoted: 1 Post(s)
That is exactly what I thought, so I took it back to the place where I replaced the battery 1.5 years ago (O'reilly Auto Parts) - they tested it and said it was fine. I then took it to Auto Zone and had them test it too, and they also said it was fine. Not sure that they will replace a battery under their replacement warranty if the tester says that it is a good battery...
NHand is offline
post #4 of 12 Old 01-17-2013, 06:29 PM
9balllrook
SHIFT_Hardcore
9balllrook's Avatar
Quoted: 8 Post(s)
9balllrook is on a distinguished road
if there is a bad cell the test will show the battery is fine. You need to do a load test, or for piece of mind, just replace the battery. Make sure there is no corrosion on the terminals as well.
Jerry's 06 SE off road
07+ Intake, Injen CAI, JBA long tubes, Gibson Cat Back, UpRev tuned, 08 caliper kit w/ Frozen/Slotted Rotors, Goodridge Stainless Steel Brake Lines, Stillen 2-row/aluminum Radiator, PML pan, TransGo shift kit, 2" PRG lift, Bilstein 5100s, 20" Fuel Pump w/295/60/20 Terra Graps, 4ga. Grounding Kit, LEDs & HIDs, Kenwood DNX-9960 Alpine PDX amps, Kef separates,
(2) underseat
subs w/Kenwood 10' slims, Twin Stinger Batteries, remote start & protection by Python
9balllrook is offline
post #5 of 12 Old 01-17-2013, 06:31 PM
Pops
SHIFT_Moderator
Pops's Avatar
Quoted: 40 Post(s)
Garage
Drivers Cig Lighter stays Hot, if you have anything plugged into it your battery will run dead. Otherwise I wouldn't let $75 stop me from fixing my problem if I were in that situation. I've had bad batteries test as good so I avoid shopping at places that replace Common Sense with an Electronic Testing Device.
- Bob
2005 Armada LE 4x4
Pops is offline
post #6 of 12 Old 01-18-2013, 06:45 PM
rsoto80
SHIFT_Hardcore
rsoto80's Avatar
Quoted: 15 Post(s)
rsoto80 is on a distinguished road
It could be a corroded negative battery cable.
04 Nissan Armada all stock
06 Dodge Charger R/T
13.8@101mph
rsoto80 is offline
post #7 of 12 Old 01-09-2014, 10:59 AM Thread Starter
NHand
SHIFT_Lurker
Quoted: 1 Post(s)
Haven't been back on here to follow up .... I replaced that battery and all is well. Thanks for the insight. Sad that batteries have a 2 year life on these vehicles, but it is what it is, I guess.
NHand is offline
post #8 of 12 Old 01-09-2014, 09:22 PM
liquid1
SHIFT_Hardcore
liquid1's Avatar
Quoted: 124 Post(s)
liquid1 is on a distinguished road
Garage
Yep the cold will Have the Almighty ZAP factor on a even slightly weak Battery.. Best way to test them Ive found is with a Load tester that pulls the Amps right outa the weak cells. Its good it was just the Battery.
2015 Pearl white Platinum 4x4 Gift to my wife..
2nd owner 2010 5.6L Armada 4x4 Titanium 52k miles Traded @ 74,000 miles.
2001 5.4L F150 4x4 Lariat extended cab on 285/17
1979 Harley Davidson Low Rider custom,2002 KTM 520 EXC Dirt bike,2007 450 Yamaha Grizzly atv
1998 honda 300 4x4 fourtrax atv
work hard to play hard.
Check out my youtube link here.
liquid1 is offline
post #9 of 12 Old 03-16-2016, 12:48 PM Thread Starter
NHand
SHIFT_Lurker
Quoted: 1 Post(s)
So ... It happened again. 2 years is definitely the life span of a battery on these beasts. I just had to replace my battery again. I bought a new one at Auto Zone that is a bit beefier. It has a 3 year full warranty. I asked them ... So, if I replace in 2 years because it is bad, then have to replace again in another 2 years, will that one still be covered. He said that it would still be covered. We shall see.
NHand is offline
post #10 of 12 Old 03-16-2016, 04:24 PM
Campfamily
SHIFT_Hardcore
Campfamily's Avatar
Quoted: 123 Post(s)
Campfamily is on a distinguished road
Quote:
I would be surprised if that was true. You have a three year warranty. If the 2nd battery fails at 2 years, then you've gotten four years out of a single purchase, exceeding your three year warranty.
- 12 Armada Platinum 4WD, Tuscan Sun (red)
- 06 Armada LE 4WD, Red Brawn, QX56 Wheels (traded)
- 04 Armada LE 4WD, Smoke (lemon lawed)
- 15 Ford Focus Electric (commuter car)
- 00 Maxima SE, Manual Trans (kids car)
- 65 Buick Skylark Gran Sport Convertible, 401 ci, 2nd owner, original condition, 70,000 miles (play car)
- Prowler Lynx 826M Travel Trailer, 26', 5000#'s
"How often we fail to realize our good fortune in living in a country where happiness is more than a lack of tragedy."
--Paul Sweeney, author
Campfamily is online now
Linear Mode Linear Mode
