long cranking time before starting-08 Armada - Nissan Armada Forum: Armada & Infiniti QX56 Forums
User Tag List
post #1 of 5 Old 12-05-2013, 12:12 AM Thread Starter
Passat514
SHIFT_Lurker
Quoted: 0 Post(s)
Passat514 is on a distinguished road
Our '08 Armada SE has to be cranked unusually long before it starts at times.
We purchased it a month ago from a Nissan dealer and it has 70k miles.
Do not know if the spark plugs have ever been replaced.
1. Is it normal for this engine to require 3-4 seconds of cranking when starting cold? (seems to fire up within a second or so when the engine is hot)
2. Our Armada has the remote start (factory I think?) but the engine doesn't start before the remote start program stops cranking it. Could the long cranking time before firing issue be related to the remote start?
3. When should spark plugs be replaced on these?
4. Any other ideas/areas to look at??
Thanks all!
Passat514 is offline
post #2 of 5 Old 12-05-2013, 01:01 AM
scr38
SHIFT_Administrator
scr38's Avatar
Quoted: 88 Post(s)
scr38 will become famous soon enough
Sounds like a problem with the remote start.
Plugs don't need to be replaced until 100K.
scr38 is offline
post #3 of 5 Old 12-05-2013, 01:40 AM
AngelVivas
SHIFT_Hardcore
AngelVivas's Avatar
Quoted: 3 Post(s)
AngelVivas is on a distinguished road
Garage
Maybe you should also get the battery checked as well just in case or check the positive connection is secure.
Angel Vivas, III
2006 Nissan Armada SE 4x2 Silver Lightning
UPRev Tuned (Cajun Style)
Gibson Cat-Back Exhaust
Cajun Catless B-Pipes
Volant Cold Air Intake
CSF 3328 Racing All-Aluminum Radiator
2" Front Leveling Kit (To Even Her Out)
Bilstein HD Front Struts
Interior LED Kit
6000 HID Kit
Nissan Black Grill Guard
AngelVivas is offline
post #4 of 5 Old 02-13-2015, 08:10 PM Thread Starter
Passat514
SHIFT_Lurker
Quoted: 0 Post(s)
Overdue update on this:
Turned out to be the fuel pump. Had the dealer check and they found that the system was losing fuel pressure when the engine was turned off. The solenoid on the fuel pump that closes the return valve was not functioning.
Ordered a new fuel pump from RockAuto.com and installed myself.
Starts and runs perfect now.
post #5 of 5 Old 02-17-2015, 06:14 AM
Achamp
SHIFT_Newbie
Achamp's Avatar
Quoted: 2 Post(s)
Achamp is on a distinguished road
Thanks for the update.
Achamp is offline
Linear Mode Linear Mode
