Heater is not working - Nissan Armada Forum: Armada & Infiniti QX56 Forums
User Tag List
post #1 of 13 Old 04-21-2006, 08:39 AM Thread Starter
ggeorgie
SHIFT_Hardcore
ggeorgie's Avatar
Quoted: 0 Post(s)
ggeorgie is on a distinguished road
I tried to look for a thread with this problem could not find any.
Anyway, I took a 2600miles trip, from Southern Cali, to Virginia, and arrived 4 days ago, I tried to turn the heater on, but it only blows cool air, and no its not on a/c setting, does any one knows what could be the problem? I opened the hood to look for what I don't know, but noticed the Radiator container cap was loose, could this be the problem?
SOLD
ggeorgie is offline
post #2 of 13 Old 04-21-2006, 11:14 AM
scr38
SHIFT_Administrator
scr38's Avatar
Quoted: 89 Post(s)
scr38 will become famous soon enough
The loose cap isn't the cause of no heat. There is a valve in the heater water line that opens when heat is called for. It sounds like this valve is not opening. You can see the valve mounted on a bracket off the firewall on the passenger side(under the hood). It has hoses connected to it.
However there is nothing you can do to check it out, you will have to go to the dealer.
Even though you said it is not set on A/C, I still have to ask - Do you have the temp controll set to hot?
scr38 is offline
post #3 of 13 Old 04-21-2006, 11:45 AM Thread Starter
ggeorgie
SHIFT_Hardcore
ggeorgie's Avatar
Quoted: 0 Post(s)
Yup, it was set to maximum heat, I guess I'll make this trip to the dealer
SOLD
ggeorgie is offline
post #4 of 13 Old 04-21-2006, 12:12 PM Thread Starter
ggeorgie
SHIFT_Hardcore
ggeorgie's Avatar
Quoted: 0 Post(s)
SCR, does it make a difference if the water( antifreeze ) level in the radiator reserve tank was low?
SOLD
ggeorgie is offline
post #5 of 13 Old 04-21-2006, 01:36 PM
aquaranti
SHIFT_Newbie
Quoted: 0 Post(s)
aquaranti is on a distinguished road
recheck you coolant level, it has to be where it is marked on the reserve tank, I had a similar problem, and that was the cause of it. also if you say your radiator cap was loose you may have lost it through their.cap must be on tight . you also may have to blead the system being that radiator cap being loose took in some air.
there is a tsb on the radiator cap being faulty, something to do with the gasket, if the gasket is deformed you may need a new cap.
aquaranti is offline
post #6 of 13 Old 04-21-2006, 03:18 PM
scr38
SHIFT_Administrator
scr38's Avatar
Quoted: 89 Post(s)
If the coolant level was low enough to get air into the system that could be the problem.
Just to clear things up, there are two caps here, one on the radiator and one on the reserve tank. Unlike many systems, the Armada's reserve tank is under pressure. The cap on the radiator isn't a pressure release cap, it just seals. That is the cap that there have been problems with. On some early caps the rubber gasket expanded and let the system leak. There is a TBS on that cap.
The cap on the reserve tank is the pressure cap. It must be tight at all times also. If the coolant level in the reserve tank gets very low then air could be drawn into the radiator as the system cools and the coolant contracts.
scr38 is offline
post #7 of 13 Old 04-21-2006, 03:42 PM
CDNArMaDa
SHIFT_Enthusiast
Quoted: 0 Post(s)
CDNArMaDa is on a distinguished road
no heat
I once owned an old olds with a rad leak, i used to wait for the heater to blow cold air, I then knew it was time to fill the rad again.
If the colant level is too low the pump will not push it through the heater core.
CDNArMaDa is offline
post #8 of 13 Old 04-23-2006, 11:19 PM Thread Starter
ggeorgie
SHIFT_Hardcore
ggeorgie's Avatar
Quoted: 0 Post(s)
update
Thanks guys for all the responses, it will only be fair to update you.
SCR,he coolant was very low, so I decided instead of going to the dealer, to stop by the auto store and buy a gallon of antifreeze, I poured more than 3/4 into the Radiator resevoir, and drove for a while, then let it cool for a while. and added the rest of the antifreeze. and started the heater again and its working. thanks for all your input. it was a close call driving 2600miles almost no coolant
SOLD
ggeorgie is offline
post #9 of 13 Old 04-23-2006, 11:26 PM
scr38
SHIFT_Administrator
scr38's Avatar
Quoted: 89 Post(s)
Now the question is where did the coolant go? Do you see any signs of a leak? Be sure to keep an eye on the level.
scr38 is offline
post #10 of 13 Old 04-23-2006, 11:36 PM Thread Starter
ggeorgie
SHIFT_Hardcore
ggeorgie's Avatar
Quoted: 0 Post(s)
Thanks SCR, will do. As for the coolant I believe it did evaporate during the trip, driving 10 to 12 hours a day straight. but still I 'll keep an eye on the level.
SOLD
ggeorgie is offline
Linear Mode Linear Mode
