what PSI in tires? - Nissan Armada Forum: Armada & Infiniti QX56 Forums
User Tag List
post #1 of 11 Old 09-22-2006, 11:27 AM Thread Starter
BostonBob
SHIFT_Hardcore
Quoted: 0 Post(s)
what PSI in tires?
Odd question I know - but I have 305/50 x 20" tires and was wondering if the proper PSI is 32? I have to admit I have NEVER checked, added or removed air from my tires in 18K miles. I run the factory 18s in the Winter. Any help would be appreciated.
BOSTONBOB
2005 LE with DVD & Tech. 20 inch MC2ning N2 Chrome wheels (dealer installed), 3A Racing Chrome Exhaust tip, 3M Clear Bra, Burton's custom painted spoiler, Protected by Zaino (the best car polish I have found)
BostonBob is offline
post #2 of 11 Old 09-22-2006, 11:38 AM
razzlee
SHIFT_Hardcore
razzlee's Avatar
Quoted: 0 Post(s)
it is different with every make/model of tire. It should say right on the side-wall. My toyo open countries are maxed out at 40psi where as my buddy has toyo m/ts and they max out at 50psi. Check your tires and if you still have trouble, take your rig to your local lube shop. Be nice, they'll help you out.
good luck.
~Clay
'05 SE 4x4
big tow, dvd, Bose
33" toyo M/Ts on stock 18"s
Injen CAI, PowerAid TBS, Painted Engine Cover
LE Chrome Grill, Chrome Billet Grill Inserts, Chrome Liftgate Trim
razzlee is offline
post #3 of 11 Old 09-22-2006, 11:46 AM Thread Starter
BostonBob
SHIFT_Hardcore
Quoted: 0 Post(s)
thanks for tip - I always thought the sidewall number was MAX pressure.
BOSTONBOB
post #4 of 11 Old 09-22-2006, 11:58 AM
razzlee
SHIFT_Hardcore
razzlee's Avatar
Quoted: 0 Post(s)
Quote:
just remember to keep all tires at the same psi. max psi is ideal for regular driving. If you live above 3000 ft, check your tire pressure more often.
~Clay
'05 SE 4x4
big tow, dvd, Bose
razzlee is offline
post #5 of 11 Old 09-22-2006, 12:38 PM
scr38
SHIFT_Administrator
scr38's Avatar
Quoted: 89 Post(s)
The side wall listing is the max pressure, don't run that. It is not the ideal pressure. 35-38 is a good starting point. Check with the maker of your tires for the proper pressure.
scr38 is offline
post #6 of 11 Old 09-22-2006, 01:22 PM
razzlee
SHIFT_Hardcore
razzlee's Avatar
Quoted: 0 Post(s)
Quote:
I have been misinformed and in turn I have misinformed. For this I am sorry>
~Clay
'05 SE 4x4
big tow, dvd, Bose
razzlee is offline
post #7 of 11 Old 09-22-2006, 11:25 PM
adjmcloon
SHIFT_Hardcore
adjmcloon's Avatar
Quoted: 0 Post(s)
I run 40psi in my Nitto terra grappler 305/50/20's. If you air them up you will decrease rolling resistance, but not too much because you'll cause improper wear.
2002 BMW 540ia sport, premium
2004 Toyota Sequoia Limited
adjmcloon is offline
post #8 of 11 Old 09-23-2006, 02:01 PM
92TripleBlack
SHIFT_Hardcore
92TripleBlack's Avatar
Quoted: 0 Post(s)
They are supposed to be run at 39PSI according to Discount Tire. Larger rims = higher pressures to stop rim damage. The makers design the tires to wear at these pressures so if you run them light you will have poor wear and be buying loads of extra tires. MAX pressure is for towing Max loads. This keeps the tires inflated instead of squished under heavy loads.
Lowered SUVs are Beneath me. W in '04. Thank me!
'05 Armada LE 4x4, Red Brawn, Graphite, Tech, DVD, Terra Grapplers 305-55-20, MB Motoring Express 20x9, 6000k HID lows, Silverstar 9005 highs & 893 fogs, Lund Stainless Steel Bug Shield, Timing advanced 2 degrees
'92 Vette Vert Black,6-Spd,Lots of mods (For Sale)
'04 G35 Sedan-Black,Sport,wing,all opt.
'02 VW Jetta GLS 1.8T (Hers)
'04 Kawi STX-15F JetSki
92TripleBlack is offline
post #9 of 11 Old 09-23-2006, 04:22 PM
sinnerFA
SHIFT_Enthusiast
sinnerFA's Avatar
Quoted: 0 Post(s)
What about the OE Contri's?
'05 Armada LE 4x4 - Red Brawn (AEM Brute Force Intake, Active Tuning Ground Kit "RED", Gibson Cat-Back, AirRaid TBS, Nitto TerraGrappler 325/60-18)
sinnerFA is offline
post #10 of 11 Old 09-23-2006, 04:27 PM
92TripleBlack
SHIFT_Hardcore
Quoted: 0 Post(s)
Quote:
35 PSI. Low pressure sensor goes off at 29 PSI.
Linear Mode Linear Mode
For the best viewing experience please update your browser to Google Chrome
