Similar Brake Issue
I've had a very similar problem. However it has happened a few times. It's not so much a grinding noise, but it is like the brakes catch and the pedal goes a bit too far and you hit the brakes too hard. You hear a sound like the spring on the pedal is catching on something. The pedal feel gets all messed up and you have to turn the truck off to get rid of the problem. You still have pressure since the pedal won't go to the floor. It won't make the sound when you aren't moving and pumping the brakes, just when you are coming to a stop. I've been waiting for it to happen again, so I can take it in while the lights (brake, slip, and VDC) come on and I don't shut it off. Those bozos seem not to be able to figure anything out unless it is in the midst of a problem. If anyone knows what the real problem is, let me know.
__________________
'05 LE 4X2
Red Braun/Graphite
Tech Package, DVD, Sirius Satellite
Silver Star Hi (Lows/Fogs blew out  )
OEM high beams in Low Beam housing
Philadelpia Eagles Hitch Cover
Factory Matched Tint Driver/Passenger
24x10 Bazo B26 with Hankook 295/40R24
