Interesting info - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 5 (permalink) Old 02-11-2014, 11:08 PM Thread Starter
Interesting info
Interesting info I came across on penetrating oils. I have never liked WD40. It isn't really a penetrating oil, and leaves a brown varnish like residue. It works good for what it was designed for, displacing moisture. (the WD stands for "water displacing")
I have used Kroil for years, but it looks like the "home brew" is the best!
Penetrating Oils
Machinist's Workshop magazine recently published some information on various penetrating oils that I found very interesting. Some of you might appreciate this.
The magazine reports they tested penetrates for break out torque on rusted nuts. They are below, as forwarded by an ex-student and professional machinist..
They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a "scientifically rusted" environment.
*Penetrating oils ........... Average torque load to loosen*
No Oil used ................... 516 pounds
WD-40 ...................... ... 238 pounds
PB Blaster .................... 214 pounds
Liquid Wrench ...............127 pounds
Kano Kroil ..................... 106 pounds
ATF*-Acetone mix......... 53 pounds
The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note this "home brew" released bolts better than any commercial product in this one particular test. Our local machinist group mixed up a batch and we all now use it with equally good results. Note also that "Liquid Wrench" is almost as good as "Kroil" for about 20% of the price.
Steve from Godwin-Singer says that ATF-Acetone mix is best, but you can also use ATF and lacquer thinner in a 50-50 mix.
*ATF=Automatic Transmission Fluid
____________
post #2 of 5 (permalink) Old 02-12-2014, 12:01 AM
liquid1's Avatar
Quoted: 130 Post(s)
Good find, Thanks..I am surprised that liquid wrench beat out PB Blaster, As I have used both for years, PB Blaster seems to be the preferred rust buster around these parts, I will give the Liquid wrench another try. Atf/Acetone would be easy to mix and have ready in a spray bottle, the Kroil I don't see , gonna have to look for it now. Interesting.. As I am a Hydraulic Field service Technician and use these sprays all the time.. sometimes with a little heat..Been buying PB Blaster for 25 years by the case and it works, But the salt is mild to wild here in NC. Gonna for sure give the others a try..Thanks for the info
2015 Pearl white Platinum 4x4 Gift to my wife..
2nd owner 2010 5.6L Armada 4x4 Titanium 52k miles Traded @ 74,000 miles.
2001 5.4L F150 4x4 Lariat extended cab on 285/17
1979 Harley Davidson Low Rider custom,2002 KTM 520 EXC Dirt bike,2007 450 Yamaha Grizzly atv
1998 honda 300 4x4 fourtrax atv
work hard to play hard.
Check out my youtube link here.
liquid1 is offline
post #3 of 5 (permalink) Old 02-12-2014, 10:25 AM
Interesting info.....let's mix up a batch and package it up.....call it "scr-oil" ......I'm already seeing the marketing campaign.....
post #4 of 5 (permalink) Old 02-12-2014, 11:03 AM
roadie's Avatar
Quoted: 25 Post(s)
ATF + Acetone
Call it TransTone.
325/60R/20 Nitto Terra Grapplers, 6" lift, tinted windows, Volant CAI, Legit Interior & Backup LED's, Torque Pro Monitoring on a Motorola DROID w/ELM 327 Bluetooth, Bilstein 5100 Front Shocks, Bilstein 5165 Rear Shocks, UpRev by seymore4 @ cajuntuning
Soon to be added, JBA LT Headers, Cajun 2.5" B-Pipes, Y Pipe and Borla 40944 Muffler.
roadie is offline
post #5 of 5 (permalink) Old 02-12-2014, 02:57 PM
Quoted: 72 Post(s)
Curious, was that synthetic ATF or conventional? I ask because synthetic oil by nature is very "capillary" and finds its way to places conventional oil just doesn't.
E&J push'n wind is offline
