Coolant Question - Nissan Armada Forum: Armada & Infiniti QX56 Forums
LinkBack Thread Tools
Old 02-02-2019, 06:40 PM Thread Starter
Coolant Question
So I was stumbling around under the hood this afternoon and was looking at the coolant in the expansion tank. Stuck a paper towel in there to see what color the coolant was and it came out yellow/green. Everywhere I have looked indicates the 2011 Armada should have blue Asian spec coolant. Can anybody give any insight on what coolant the vehicle should have? I'm not necessarily worried about what's in there, but if I ever need to top off the coolant that makes that a little more complicated.
Old 02-02-2019, 10:05 PM
I use Nissan OEM coolant and it is green.
Labeled L248SP
Part # 999MP AF000P
Edit to add I got an 06
staplebox is offline
Old 02-03-2019, 08:08 PM Thread Starter
That's interesting. Peak shows that a blue coolant is recommended. Good to know that is probably wrong.
https://peakauto.com/products/antifr...ded-life-blue/
Old 02-05-2019, 10:47 AM
Jon
In all Nissan's 2010 and up use the blue coolant, 2009 and down use green.
Jon is offline
Old 02-05-2019, 04:14 PM Thread Starter
The coolant in my 2011 is definitely green and not blue. I don't have any service records from the previous owner except for the basic and useless CarFax. I wonder if the cooling system was serviced previously and different coolant was installed.
Radiators and other components typically have manufacture dates on them. Does anybody know where/if the manufacture date is stamped on the radiator?
Old 02-10-2019, 07:04 PM
My 2010 has green in it. That's what I found it in when I bought it 4 years ago and never had any problems with cooling.
jfsiv is offline
Old 02-11-2019, 09:16 AM Thread Starter
Let me muddy the water further. Both the service manual and the owners manual state that the vehicle is filled at the factory with blue coolant. See attached.
This is not an issue for me now, but if I have a need to either replace or top-off the coolant i'm unsure of what to use.
ID:	45301   Click image for larger version
Name:	Owner Manual Coolant Info.jpg
Old 02-15-2019, 06:32 PM
Jon
2011 uses blue
Jon is offline
Old 02-15-2019, 07:55 PM Thread Starter
Maybe Nissan used the green coolant in the 2011 models until their supply was exhausted then switched to the blue.
