Rear air delete - Nissan Armada Forum: Armada & Infiniti QX56 Forums
 7Likes
post #1 of 34 (permalink) Old 03-08-2019, 09:49 PM Thread Starter
Jnight's Avatar
Rear air delete
Well I started my suspension install today... for those of you that dont know. I'm going with moog 81085s, 4600s and Rancho quick lift spacers. I figured I would also take care of my brakes and rear wheel hub assembly's. I started at 8AM it was 18į here in WNY. Took some before pictures jacked up the truck to get it on stands. Get all four wheels off start spraying down shock bolts(PB Blaster), remove all brakes (calipers, caliper brackets, pads and rotors). Started wire brushing all the rust off calipers and brackets. Back for another spray down (repeated this ever 20 mins or so until 12:30). Spray painted all calipers and brackets. Also hit front knuckles and dust shrouds. And started trying to remove bolts and axle nuts. The DS rear axle nut wasn't even hand tight. Surprised it hasn't gone out yet. PS rear upper shock bolt came off with ease, just using my 24" breaker bar. All others a seized to bushings! I tried mapp gas, my big IR impact, nothing would break them loose. So my buddy will be coming by with his cut off torch and well get it done my next days off. I still need to get the rear hubs off too. I used my whole afternoon trying to get the last three shock bolts off.
https://youtu.be/EVxanq9bSS4
Sent from my SM-G960U using Tapatalk
Jnight is offline
post #2 of 34 (permalink) Old 03-08-2019, 11:26 PM
Quoted: 35 Post(s)
Why not use a grinder and a skinny wheel?
2011 QX56 loaded with everything including, you guessed it, HBMC
Stuffed with 285/55r22 Nitto Terra Grappler G2s
Highbrow Hillbilly w/HBMC is offline
post #3 of 34 (permalink) Old 03-09-2019, 06:49 AM Thread Starter
Jnight's Avatar
Dont want to cut bolt. I'll be burning through bushings.
Jnight is offline
post #4 of 34 (permalink) Old 03-09-2019, 08:22 PM
Quoted: 35 Post(s)
Huh, I'm having trouble envisioning this. Looking forward to some more pics.
post #5 of 34 (permalink) Old 03-09-2019, 08:39 PM Thread Starter
Jnight's Avatar
It'll definitely be interesting.. Plan is to burn through the shock eye splitting it open like a horse shoe. Then cut out the rubber bushing, and finally cut open the inner bushing same as above. Wish me luck!
Jnight is offline
post #6 of 34 (permalink) Old 03-09-2019, 10:05 PM
PetitFrereArmada's Avatar
Quoted: 226 Post(s)
Goodluck indeed. And great work doing this and sharing pics.
I am definitely going to be watching this for sure.
Jnight likes this.
PetitFrereArmada is offline
post #7 of 34 (permalink) Old 03-09-2019, 10:17 PM Thread Starter
Jnight's Avatar
Thank you! I'll definitely be keeping everyone posted. Much more pictures and videos to come. Hopefully upcoming videos won't be so explicit... I was slightly aggravated knowing I've been driving around with that axle nut having my 2yr old in the back seat.
Jnight is offline
post #8 of 34 (permalink) Old 03-12-2019, 04:08 PM
good luck and let us know how it handles after.
Jnight likes this.
dean2000 is offline
post #9 of 34 (permalink) Old 03-13-2019, 07:50 PM Thread Starter
Jnight's Avatar
Update, I got the shocks off without completely destroying the bolts. Also was able to get a few more things done. Removed my compressor and mounted something a little more useful in its place. I will need to get a spring compressor considering I was unsuccessful getting either balljoint loose. Soon as I get one I'll be able to finish this project. It really sucks having my only personal vehicle out of commission. I still need to get hubs removed.. lots to come. Photos attached
Jnight is offline
post #10 of 34 (permalink) Old 03-14-2019, 12:27 AM
gt601's Avatar
Quoted: 21 Post(s)
FYI. In the future. You can buy all the hardware at the dealer. When I did my front struts I pre-bought all nuts, bolts and bushings just so I would have them in case of any problems. I think I had 30-40 bucks in parts.
Paul
gt601 is offline
Factory ride height for 2005 SE w/Tow Package (air suspension delete) DanF. Suspension/Tires/Brakes 13 03-23-2019 10:18 AM
Rear Air Suspension Delete - 2WD Rontgen Suspension/Tires/Brakes 4 08-08-2018 10:28 AM
Air Ride Delete, Strutmaster Nw1582 Suspension/Tires/Brakes 7 10-24-2017 08:27 AM
Issue with rear air shocks bleeding air Dieselguy Suspension/Tires/Brakes 0 10-13-2017 02:26 PM
