Compartment mounted GPS - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 12 (permalink) Old 02-28-2011, 05:02 PM Thread Starter
97trakin's Avatar
Quoted: 12 Post(s)
Compartment mounted GPS *Pics up*
Wired up and semi hard mounted my GPS.
Had to tap into some power.
Mounted a 12volt outlet in one of the flip downs so if I ever decide to upgrade it's just plug and play. Outlet can also be used for any 12 accessory if needed.
GPS mount is installed with industrial strength 3-M double sided tape. GPS clips in and 'out' if needed.
Fliped up and out of sight. Next move is a micro switch so it turns on automatically when opened and off when closed. Works great so far.
97trakin is offline
post #2 of 12 (permalink) Old 02-28-2011, 05:10 PM Thread Starter
97trakin's Avatar
Quoted: 12 Post(s)
Pics didn't show up :-( . I'll try again.
*Fixed it*
97trakin is offline
post #3 of 12 (permalink) Old 03-01-2011, 12:02 PM Thread Starter
97trakin's Avatar
Quoted: 12 Post(s)
Installed a micro-switch that triggers on the compartment door. Turns unit on when opened and off when closed.
97trakin is offline
post #4 of 12 (permalink) Old 03-01-2011, 12:26 PM
nice install, good use of the sunglass holder!
post #5 of 12 (permalink) Old 03-01-2011, 03:37 PM Thread Starter
97trakin's Avatar
Quoted: 12 Post(s)
Thank you sir.
I use the small flip down compartment right after the digital compass for my sunglass now .
I put a very low amp fuse (4amps) in the micro switch circuit just in case.
While I was in the overheads I went ahead and got the wiring ready for when I install the overhead DVD monitor.
97trakin is offline
post #6 of 12 (permalink) Old 03-02-2011, 12:14 AM
Taze's Avatar
Send a message via AIM to Taze Send a message via MSN to Taze Send a message via Yahoo to Taze
Nice addition with the micro switch 97trakin...That does look clean. Is it not too high for you to see well?
Check out:
Amaya in my garage at
ABM in my garage at
Tigger in my garage at
Taze
Taze is offline
post #7 of 12 (permalink) Old 03-02-2011, 02:52 PM Thread Starter
97trakin's Avatar
Quoted: 12 Post(s)
It's not bad at all. It's lower and forward of the factory compass.
97trakin is offline
post #8 of 12 (permalink) Old 03-05-2011, 08:42 PM
Sweeet!!!!!!!!!!!
post #9 of 12 (permalink) Old 03-12-2011, 11:26 PM
Invanity's Avatar
That's pretty cool....I wonder if a larger/wider GPS will look better.
I really like the micro switch idea, that's awesome
-Eli
Thanks guys
Invanity is offline
post #10 of 12 (permalink) Old 03-13-2011, 11:36 AM Thread Starter
97trakin's Avatar
Quoted: 12 Post(s)
I clipped my father-inlaw's wide screen in and it looks really nice. Really fills the space width wise.
97trakin is offline
HTML code is On
