Running light problem with new hitch - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 11 (permalink) Old 03-06-2008, 08:01 PM Thread Starter
Help! I have just installed a new hitch on my wife's 07 SE, but my trailer has no running lights. Everything else works as far as turn signals and brake lights. This hitch, plug and relays came from Nissan dealer. I used an adapter to go from 7-pin connector to 4; could this be the problem? It was working on my truck.
rlcamiii is offline
post #2 of 11 (permalink) Old 03-06-2008, 09:56 PM
Did you install a relay under the dash to the left of the steering column? That relay controls the trailer running lights. The two relays for the turn signals are in the relay box under the hood.
post #3 of 11 (permalink) Old 03-07-2008, 04:57 PM Thread Starter
running light problem
I followed OEM directions that came with hitch from dealer. It said nothing about relay under the dash. For electric trailer brakes it mention jumper harness connection under dash. I talked with service department at Dearlership and he said the problem must be with the relays being in the wrong spot. I told him they were only 3 spots open under the hood, 2 for the small relays and 1 for the large relay.
rlcamiii is offline
post #4 of 11 (permalink) Old 03-10-2008, 11:36 PM
The 06 and up are different than the 04-05. There is a relay that is under the dash. It is relay 1, and is indicated as "A" in the attached drawings.
Name:	06 turn relays.JPG
ID:	6412   Click image for larger version
Name:	06 up trailer tail light power.JPG
ID:	6413   Click image for larger version
Name:	06 up trailer tail light wiring.JPG
ID:	6414   Click image for larger version
Name:	06-up Tow Relay 1.JPG
post #5 of 11 (permalink) Old 03-14-2008, 03:10 PM
How do you get to the relay under the dash? I installed the 3 inside the black box by the battery. if this helps my trailer does not have brakes, just an 8x10 snowmobile trailer.
drosa is offline
post #6 of 11 (permalink) Old 03-14-2008, 06:15 PM
pja454's Avatar
i'm having the same problem have you figured it out yet. do we need to buy another relay for the dash?
pja454 is offline
post #7 of 11 (permalink) Old 03-14-2008, 06:58 PM
On the 06 and up you need the relay (marked A in the drawing in my post above) to have running lights on the trailer. This relay is not used on the 04-05s.
post #8 of 11 (permalink) Old 04-15-2008, 05:57 PM
thank you, i've been working on running lites 2007 armada, plugged in the xtra relay under the dash and eureka. Different than my 2004 titan
thanks again
bennbatterson is offline
post #9 of 11 (permalink) Old 04-15-2008, 10:13 PM
Welcome to CA rlcamiii & bennbatterson!
post #10 of 11 (permalink) Old 11-08-2008, 08:08 AM
LafayetteOwner's Avatar
Solution and sticky post ...
This trailer light topic and all related threads should be a sticky post containing the ultimate solution.
As far as the exact placement of that final relay under the driver's side dash? An excellent solution was posted by Roadhog here . Of course, I wouldn't have gotten very far without the important information from scr38.
Thank you!
Chris
Chris
'06 Smoke SE
(Air Box Mod, K&N Drop-In, Custom Leather, Custom DVD & Flipdown Monitor)
LafayetteOwner is offline
