Radiator removal/replacment - Page 6 - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #51 of 60 (permalink) Old 07-02-2015, 03:44 PM
Quoted: 72 Post(s)
SE, I think you meant to say 6 pt. 6 pt sockets and wrenches are ALWAYS better when turning nuts and bolts. A 12 pt does in fact give you the possibility of rounding the corners because that is all that is "gripped." A 6 pt makes full contact with each side of the nut or bolt. Hence an impact socket will NEVER be a 12 pt but rather 6 pt.
There are 6 pt wrenches that will do a job like this better when the corners of the nut have been rounded.
E&J push'n wind is offline
post #52 of 60 (permalink) Old 07-14-2015, 11:49 AM
SE Off Road1's Avatar
Quoted: 58 Post(s)
I actually used a ratcheting 12 pt. open-end on this application since it seemed to grip the nut better than my 6 pt. The fan bolts are very soft metal and with the 12 pt. there is more points of contact on the fastener. I do agree through a 6 pt. is normally less likely to round off a fastener.
[IMG][/IMG]
SE Off Road1 is offline
post #53 of 60 (permalink) Old 09-16-2015, 07:53 AM
Got home last night to coolant on the floor and a cracked radiator. I started the removal process last night and got to removing the fan and the first bolt sheared. I stopped at that point and put everything back together thinking it will have to go to a shop. This morning I am wondering if that pulley the fan attaches to is easily removed? If any more of the bolts snap I could drill them out after removing the pulley. Can anyone help?
AlbaTiVo is offline
post #54 of 60 (permalink) Old 09-16-2015, 09:10 AM
Quoted: 58 Post(s)
The bolts need to be removed before you can remove the pulley. What type of wrench were you using to remove the bolts? You need a tight fitting open-end with No Play. A swift tug will break them free pretty easily. If there is any play between the wrench and fastener rounding will occur as you discovered. Can you get a small vice grip on the bolt?
What year is your truck? How many miles?
post #55 of 60 (permalink) Old 09-16-2015, 09:22 AM
Okay, so if I take out the rest of the bolts, even if they snap I can remove the pulley and drill the bolts out? Using a 10mm open-ended wrench and it broke free, but sheared off - not rounded at all. It's a 2008 with 152k.
AlbaTiVo is offline
post #56 of 60 (permalink) Old 09-16-2015, 09:50 AM
Quoted: 58 Post(s)
Yes, once all the nuts are removed the pulley can be removed very easily. You can then replace the pulley and studs. Sorry, I misunderstood I thought you rounded the fastener. Once you get the fan out of the way the rest of the job is very straight forward.
post #57 of 60 (permalink) Old 09-17-2015, 12:05 PM
Thanks for your advice!
AlbaTiVo is offline
post #58 of 60 (permalink) Old 05-20-2016, 04:28 AM
I just completed this project on my '07 Qx56. Same large crack in the plastic on the passenger side. A HUGE THANK YOU to "Fix It Angel" on YouTube for posting a step by step video of his repair! Here's the link: https://youtu.be/81GzolKQ0Yw I used his video and this thread on ClubArmada to replace my radiator. I ordered the Spectra Premium CU2691 Radiator from Amazon for $143. It's the same as Autozone carries but I saved $90 by ordering online. Perfect fit. I would have loved to go with Stillen all aluminum, but I bought a few tools with the money saved instead. In the video, he used a prybar to wedge the fan while he loosened the nuts. Worked for me, too. Thank you to all who take the time to share their knowledge and experience. I saved a ton of money by doing this project myself!
MyGarage is offline
post #59 of 60 (permalink) Old 05-21-2016, 12:37 PM
Believe_ET.2's Avatar
man, looks like the radiators on our madas goes bad alot. My 08 when i only had about 30k or so on her my radiator was leaking too. luckily i was still under warranty so they just replaced it w a brand new one. I did not pay a dime and i saw the bill, WOW! almost 2 thousand dollars and some change... I was really lucky i still had the warranty. Now, no more leaks...
Believe
-2008 LE w Tow Package
-4 piece Billet Grill
-Bug Deflector guard
-Sunroof wind deflector
-HID 6k lows (fogs soon)
-Air Box Mod with K&N Filter (thanks to this forum I was able to do it myself)
-screw on exhaust tip
-15% tint front windows
Believe_ET.2 is offline
post #60 of 60 (permalink) Old 09-19-2016, 09:16 PM
You definitely want to get away from plastic. I installed all aluminum beauty of a radiator in my 06 Friday. I just feel compelled to share this info. I bought it from Champion Cooling and it has the trans cooler built in. Top and bottom polished looking as sweet as it performs. I waited way too long to do this and had been packing 4 gal of water to go to work and back home in case of loss of fluid. Well this radiator was only $209 plus about $30 shipping. Took a week to get here in Ohio from California but I am satisfied to date. Took longer than advertised to remove original but the new install was about 35 minutes and weighed a fraction of the original even when drained. I hope this helps others looking to go all metal.
06armadaman is offline
