Window Defroster - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 6 (permalink) Old 11-30-2008, 01:05 PM Thread Starter
Nickoli415's Avatar
Window Defroster
Hey guys, long time no see. Well now that it started snowing here in Germany, wondering if there's a way to test the defrosters on the 3 rear window's dont know what there called but there the little heat strips that run a long the windows. And also the side mirrors too if possible. Thanx.
2005 LE
Nickoli415 is offline
post #2 of 6 (permalink) Old 11-30-2008, 01:55 PM
CdnInAz's Avatar
they are resistance elements - same principle as stove elements. If they have failed, most likely cause is a break in the lines on window. A starting test is to disconnect at the window, then test resistance across the window. If zero resistance then you have an open. Auto supply stores sell a repair kit, but it is only useful if you can find the exact location of open. This is hard to describe, hope this helps.
I'm not certain on these, but assume they are same type of resistance elements. If so, same test can be done, but you'll have to pull door apart to get to connector.
- a "retired CA member"
had a 2007 LE 4x4, BigTow, Nav, DVD. Mods:
rear exit,
(forced when crappy Contis died early), added
under transfer case & fuel tank
- Armada replaced May09 with 2004 Toyota 4Runner 4x4 (a lighter more nimble rig without the terrible Nissan rattles, not as big but carries and tows enough for me)
went to Discount Tire for Goodyear SAs on my 2000 Tundra, again for SAs on my 2007 Mada, and hope to again soon for SAs when the 'normal' street tires are done on my 2004 4Runner
CdnInAz is offline
post #3 of 6 (permalink) Old 11-30-2008, 01:58 PM
The strips on the rear side windows are the radio antennas, not defrosters.
post #4 of 6 (permalink) Old 11-30-2008, 02:05 PM
CdnInAz's Avatar
yes, opps my bad - the OP did write "3 rear windows", I even quoted that. So to be clear for OP - my post above only applies to the actual rear window. Side windows do not have resistance defrosters.
rear exit,
CdnInAz is offline
post #5 of 6 (permalink) Old 12-01-2008, 06:30 PM Thread Starter
Nickoli415's Avatar
I would of never guessed the side ones were antenna's!!!! I actually tried to look for the antenna on the mada with no luck, but now i know. Thanks for the quick response!!!
2005 LE
post #6 of 6 (permalink) Old 12-01-2008, 08:36 PM
Russian ARMADA's Avatar
There isn't any need to defrost the trunk windows.
Russian ARMADA is offline
