How to change transfer case oil - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 6 (permalink) Old 09-29-2009, 09:06 PM Thread Starter
smokeonmada's Avatar
I searched for; but i had no luck. I am going to be changing front axle, transmission, TRANSFER case, and rear axle oil. I know how to change all the other ones; but i don't know how to change the transfer case oil. So any help would be greatly appreciated.
2005 Nissan Armada LE, TOW PACKAGE, and TECH PACKAGE.
MODS: INJEN COLD AIR INTAKE, 2* Timing advance, EBC dimpled and slotted front rotors, 25% tints on front, burnout mod, Screen delete,TB coolant by-pass, OEM 2009 Titan 20's wheels and tires, 55watt 6k HIDS lows and 3K fogs. The list continues on yet again, rancho 9000XL front struts(JUNK!) and Cooper AT3 tires 275/60/20, Gibson cat back exhaust. Meyer plow. PGR built Bilstien 5100 plus HD springs in front by Greg. JBA LT headers, catted Cajun b pipes 2.5 and Uprev.
smokeonmada is offline
post #2 of 6 (permalink) Old 07-29-2012, 11:20 PM
Anyone have any tips on this. I want to do this in a couple days and have no idea what I'm doing..
chrisleduc1 is offline
post #3 of 6 (permalink) Old 07-30-2012, 09:12 AM
scot0410's Avatar
There are drain and fill plug bolts just as on the differentials. I'll try to dig up a diagram.
It's an easy job once you locate the drain and fill points.
Sent from my Autoguide iPhone
Scott
06 SE 4WD Red Brawn, Leather, Tow Package, 2* timing, Borla dual exhaust, Injen cai, 4300k hid, Hyper Grounding Wire, Bilstein 5100s, PRG Mini Lift, Fumoto Oil Drain Valve, Second row bench changed to captains chairs and Console,Hunter Bull Bar, Nitto Terra Grappler 325/60/18.
scot0410 is offline
post #4 of 6 (permalink) Old 07-30-2012, 11:30 PM
Scott
That would be great. Any recommendations on procedure or product?
post #5 of 6 (permalink) Old 08-06-2012, 07:20 PM
I'm about to do mine in my 05 QX. I did it a few years ago in my 05 Titan and it was easy.
loosen the fill plug first so you don't drain it all then figure out that you can't get the fill plug out.
I read you will need a little over 2 quarts of ATF fluid compatible with Matic D or Dex III.
armadillo is offline
post #6 of 6 (permalink) Old 03-02-2017, 02:23 PM
ran into some issue. removed the fill plug, and about a quart of ATF came out.....something is not quite right.
lot more came out when drain plug was removed....
it could be because front of my was was jacked up ?
I measure just a little under 3 quart came out. but only 2.5 quart went back in.
Edit: had the car level and checked it again. Same thing. So it only took 2.5 quart
bellwilliam is offline
