Fog Light Bulb Replacemet - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 7 (permalink) Old 10-03-2010, 11:32 AM Thread Starter
I have a 2005 Armada LE. How does one go about replacing a burned out fog light bulb and what is the correct bulb to use?
Armadian is offline
post #2 of 7 (permalink) Old 10-03-2010, 03:46 PM
baseballfanz's Avatar
OEM is 899
baseballfanz is offline
post #3 of 7 (permalink) Old 10-03-2010, 04:02 PM Thread Starter
Any recommendations on how to get the old bulb out? A prior post suggested that I remove the connector from the lamp and undo the retaining nut. The unit is supposed to slide out the front.
I think the 2005 unit has some alignment screws that are keeping it from sliding out the front.
Armadian is offline
post #4 of 7 (permalink) Old 10-03-2010, 07:20 PM
RC340's Avatar
I thought once you unplug wire harness you just twist bulb out, no need to slide unit out thru the front, haven't replace mind yet
RC340 is offline
post #5 of 7 (permalink) Old 10-04-2010, 01:33 PM
All you have to do is turn the connector and release it from the housing. Should take no more that 3-5 minutes to replace both fog light bulbs!
post #6 of 7 (permalink) Old 10-04-2010, 01:46 PM
Silverstar bulbs are nice and bright for the fogs, calls for 881 which didn't work, 880 worked, different angle.
post #7 of 7 (permalink) Old 10-05-2010, 06:11 PM Thread Starter
2005 Armada Fog Light Replacement
Thank you to those who replied.
I had called the closest Nissan Dealer, Boyland of Macomb Township Michigan and spoke to the Service Manager. He told me that I needed to remove the wheel well guard to access the bulb. I told him that I already had my hand on the bulb but wasn't certain on how to remove and replace it. He told me it was too complicated to explain and that I needed to bring the car in for service evaluation. ********"Right" !
I took your advise and removed the connector, turned the bulb slightly and it came right out. The new bulb that fit properly was a Sylvania 899.
It took less than 5 minutes.
Thank you again.
Armadian is offline
