How to reset the TPMS - Page 4 - Nissan Armada Forum: Armada & Infiniti QX56 Forums
LinkBack Thread Tools
Old 05-24-2016, 06:30 AM
glover4's Avatar
My guess is you probably have a bad sensor in one of the wheels.
glover4 is offline
Old 05-29-2016, 11:58 PM
How will I know which one is bad. To replace all of them?
dusansk is offline
Old 11-18-2016, 01:26 PM
How about a 2005?
Would it be the same for a 2005??
ml8766 is offline
Old 12-10-2016, 09:05 PM
bheintze's Avatar
Quoted: 20 Post(s)
Recently relied on this thread to reset TPMS. Just wanted to add that, when starting the reset process, my light blinked pretty quickly, making me think I was doing it wrong. However, I went through with instructions and light was reset.
Thanks for this info!
2013 Armada Platinum Reserve
2017 Chevy SS
2011 A5 Cab/quattro
bheintze is offline
Old 10-16-2017, 02:50 PM
SGreenlyn's Avatar
Quoted: 68 Post(s)
3 of 4 TPMS sensors on my Armada are dead at 200K, and I have no idea which tire is still reading out.
Rather than continue to rebuild the semi-useless factory system, I bought a TPMS system from Amazon ($60) and it works great. It only takes a few minutes to install, it works by replacing the valve stem caps with ones that integrate wireless pressure sensors, plus a cigarette lighter gauge.
It has audible warnings that are programmable and it reads pressures by tire position. Readings match my tire pressures exactly, plus I can see the psi changes in real time as outside air temperature changes, etc. There is also an internal high air temperature warning. Very happy with it.
Photos...
ID:	41898   Click image for larger version
2005 Armada LE 207K miles,
with 6000K 75W HIDs,
SGreenlyn is offline
Old 01-29-2019, 12:45 PM
I don't see the white wire under my 2nd Gen Armada (2018 Platinum Reserve) there seems to be a white plug that is mounted near the OBD port but it has multiple wires and pins on it. Would just disconnecting the battery do the reset? Does anyone with a newer Armada have a procedure for the TPMS reset that works?
Shodan is offline
Old 01-29-2019, 01:27 PM
I just tried to reset the battery and it looks like it got the TPMS light to flash but it did not work for me. When it went solid I still did not get any pressures displayed on my display. I checked the tire pressures afterwards and they were up a bit, but that is probably due to the tires warming up. How close do the pressures have to be to the ones posted? I probably will try it again but on a warmer day. Its freezing today here and I don't feel like freezing my fingers again today.
Shodan is offline
Old 01-29-2019, 03:05 PM
Quoted: 161 Post(s)
Originally Posted by Shodan View Post
I just tried to reset the battery and it looks like it got the TPMS light to flash but it did not work for me. When it went solid I still did not get any pressures displayed on my display. I checked the tire pressures afterwards and they were up a bit, but that is probably dude to the tires warming up. How close do the pressures have to be to the ones posted? I probably will try it again but on a warmer day. Its freezing today here and I don't feel like freezing my fingers again today.
Were you driving when you checked to see if the pressures were displaying? You won't see anything but ** if you haven't been moving for a mile or so (perhaps longer if it's really cold outside).
Old 01-29-2019, 03:39 PM
Yeah I went for a drive, the light was initially flashing and then went solid. Thats when I checked the pressures and they all showed blanks.
The dealer where I bought the car has now told me that they would program my TPMS sensors for free for the winter tires so I think I'll take them up on the offer.
Shodan is offline
Old 05-03-2019, 02:20 PM
Could anyone help me to locate the TPMS connector for the QX80/2nd gen Amarda? My parents has a 2017 QX80, the light came on after they switched oem wheels from 22” to 20”. I do see a connector next to OBD but it has 5 wires connected
huanhb is offline
