ATF Drain and Fill Pics. - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 23 (permalink) Old 02-20-2011, 01:45 PM Thread Starter
scot0410's Avatar
The first pic is the measured container which holds 5.3 quarts. Enough for a drain and fill.
The second is the ATF pan with drain bolt.
The third is ATF draining.
The fourth is the drained ATF fluid.
The fifth picture shows how I marked the amount of old ATF drained. In case you do not have a measured container just mark the level of drained ATF with a piece of tape as shown. This is done so you can put in the same amount of new ATF that you took out.
ID:	9405   Click image for larger version
ID:	9406   Click image for larger version
ID:	9407   Click image for larger version
ID:	9408   Click image for larger version
06 SE 4WD Red Brawn, Leather, Tow Package, 2* timing, Borla dual exhaust, Injen cai, 4300k hid, Hyper Grounding Wire, Bilstein 5100s, PRG Mini Lift, Fumoto Oil Drain Valve, Second row bench changed to captains chairs and Console,Hunter Bull Bar, Nitto Terra Grappler 325/60/18.
scot0410 is offline
post #2 of 23 (permalink) Old 02-20-2011, 01:55 PM Thread Starter
scot0410's Avatar
First pic shows that I Poured old ATF into waste containers. I then cleaned out the measured container.
Second picture shows filling measured container with new ATF with the same amount which was drained. To the tape mark.
The third picture shows the ATF charging (filling) tube.
The fourth picture shows container of new ATF with same amount drained ready to be poured into the charge tube.
Every 15k miles or so I perform this procedure three times with a few hundred miles in between. This is the 2nd drain in this cycle. With the first cycle drain I always drop the pan to clean the magnets and inspect the pan. The next two are just a drain and fill.
NOTE: I do this with my Armada warmed up so the ATF is hot when drained. I let the container of drained ATF sit until it cools down before marking the amount. I do this because when hot the ATF is expanded and when cool it is a little lower in the container. Since I am filling with cool ATF I want the level to be accurate. It doesn't lower it much at all, but after doing this a bunch of times it can make a difference. And of course, always check the fluid level with the dipstick for accuracy.
I think with the next pan drop I am going to install a PML transmission oil pan. I like the idea of extra ATF working to keep things smooth in there.
ID:	9410   Click image for larger version
ID:	9411   Click image for larger version
ID:	9412   Click image for larger version
scot0410 is offline
post #3 of 23 (permalink) Old 02-20-2011, 04:35 PM
Rumplecat's Avatar
Quoted: 44 Post(s)
Thanks for the great write-up!
Rumplecat is offline
post #4 of 23 (permalink) Old 02-20-2011, 07:17 PM Thread Starter
scot0410's Avatar
Thanks Rumplecat. I just wanted to show others just how easy it really is and hopefully those who were nervous about attempting this will give it a shot.
scot0410 is offline
post #5 of 23 (permalink) Old 02-20-2011, 07:55 PM
esMada's Avatar
I agree, thanks for the awesome write-up and pics...I truly appreciate the time and effort you put in this. I've been thinking about changing my ATF but was a little afraid to attempt this but you have certainly made it easy for anyone you might want to do this. Thanks again.
esMada is offline
post #6 of 23 (permalink) Old 02-21-2011, 08:05 AM
earldjjones's Avatar
Super job Sir. Thanks for removing some of the mystery surrounding the tranny fluid change. I really like how you show how to replace the exact amount of fluid!
05 LE
nav,dvd.rear cam, 2 degree timing, chrome door mouldings, painted running boards. dark burlwood woodgrain,chrome halo hid headlights w/led accents , chrome bumper fillers, chrome rear door handles & fog bezels,hid fogs, 22inch black, chrome and polished rims wrapped in 305/45/22 yokos, led accents for tail lights, black and chrome billet grill w/led backlit Nissan emblem
Click Here and visit My Gallery!-
earldjjones is offline
post #7 of 23 (permalink) Old 02-21-2011, 10:01 AM
Thanks Rumplecat,
Good write up and clear pictures make it very simple and easy to understand. Now just need 13K more miles and I will do my first ATF change.
SF180A is offline
post #8 of 23 (permalink) Old 02-21-2011, 10:13 AM
second the motion. Great Write up. that will save me some money instead of going to a lubrication shop. Are you using synthetic atf or just the recommended nissan atf? thanks in advance.
Phantera9mada is offline
post #9 of 23 (permalink) Old 02-21-2011, 10:18 AM Thread Starter
scot0410's Avatar
Thanks.
I use Amsoil synthetic ATF. It meets Nissan specifications. The recommended Nissan S matic is a synthetic ATF too.
scot0410 is offline
post #10 of 23 (permalink) Old 02-21-2011, 01:59 PM
Is there a seal to use when dropping the pan? Is there a source online?
ericchile is offline
