bosch or akebonos - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 9 (permalink) Old 03-30-2011, 11:56 PM Thread Starter
bosch or akebonos
How can I tell what calipers my 2006 SE Off-road uses without pulling off wheels. also please advise which size and thickness of pads/rotors to use.
Trying to order the correct parts
Madadad is offline
post #2 of 9 (permalink) Old 03-31-2011, 08:42 AM
scot0410's Avatar
You can measure the rotor diameter. If the rotor is one or the other the caliper will be the same make.
Bosch rotors are 320mm = 12.60in. (approx.)
Akebono rotors are 350mm = 13.78in. (approx.)
I have a Bosch sticker on the inside of my brake (on all four) which I can see by looking around the back side of my wheels.
06 SE 4WD Red Brawn, Leather, Tow Package, 2* timing, Borla dual exhaust, Injen cai, 4300k hid, Hyper Grounding Wire, Bilstein 5100s, PRG Mini Lift, Fumoto Oil Drain Valve, Second row bench changed to captains chairs and Console,Hunter Bull Bar, Nitto Terra Grappler 325/60/18.
scot0410 is offline
post #3 of 9 (permalink) Old 04-01-2011, 04:56 AM
Kooshtaka's Avatar
Quoted: 103 Post(s)
^ as Scot said... nissan was handy enough to put a little sticker on the inward facing side of the brakes for the BOSCH... not to sure if they did the same with the Akebono...
'05 Mada LE Slate
Kooshtaka is offline
post #4 of 9 (permalink) Old 04-01-2011, 09:11 AM
Tarantula71's Avatar
Something you might want to look into is that 06's made later in the year use 07 braking system. so you might want to call the dealer and give your vin so they can tell you i found out the hard way.
BigBoyBlue
Protected by Viper & Remote start, K&N drop in, 20% Tint all around, 2 10" Bazooka's
, Vent visor's in channel,Bug Deflector, Durango gone bye bye son totaled it!
Tarantula71 is offline
post #5 of 9 (permalink) Old 04-01-2011, 12:17 PM
Kooshtaka's Avatar
Quoted: 103 Post(s)
^the production month and year should be in the driver's side door jam (so no need to call dealer with vin, unless you have a good raport with your dealer).
If you give this date to the helpfull people at R1concepts then you will be golden!
'05 Mada LE Slate
post #6 of 9 (permalink) Old 09-30-2013, 04:55 PM Thread Starter
Thanks for all the info people!
Madadad is offline
post #7 of 9 (permalink) Old 09-30-2013, 07:33 PM
drewcs's Avatar
The bosch sticker doesn't mean you have the 320mm discs. My May/06 LE had the bosch sticker on all 4 shields but the 350mm front akebono discs. I would measure to be sure. It helps that the rear discs on all Madas are the smaller 320mm and you can compare your front discs to the back.
I have R1's with 23k and they are developing a pulse. Some other members are reporting similar issues. I liked them and great price...but just wanted you to know before you buy. When I bought from R1 they could not tell which size disc my '06 would have by the production date and assumed 320mm. They were great and replaced them without issues.
'06 LE, Airaid MXP CAI w/dry filter - BullyDog GT w/regular tune - 20" Titan wheels w/Cooper ATP's - Int/Ext LED conversion - 5000K HID low beams - Bilstein HD - Amsoil Synthetic everywhere - Power Stop drilled/slotted rotors w/ceramics pads
drewcs is offline
post #8 of 9 (permalink) Old 10-02-2013, 02:35 AM
blackArmada_Dxb's Avatar
Yes, you have to measure to be sure. It is also normal for rotors to develop a slight vibration after extended use. Rebed them and you should be good to go!
My Build Thread:
blackArmada_Dxb is offline
post #9 of 9 (permalink) Old 01-22-2014, 12:00 AM
marked. I had the same question earlier today
GNOLAUM is offline
