How to get fog lights on with parking lights - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 8 (permalink) Old 09-26-2011, 05:14 PM Thread Starter
I have a 2006 QX56 and I'm trying to figure out how to get the fog lights to come on with the parking lights. I had an '01 Maxima and I found a thread of how to do it and it worked perfect. Just checking to see if anyone has done this yet.
blackqx56 is offline
post #2 of 8 (permalink) Old 09-27-2011, 08:29 PM
spta97's Avatar
Quoted: 81 Post(s)
I believe you are referring to the "jumper" mod or "fuse" mod? I did that and ended up blowing fuses and knocking out my interior lights and dimmer switch. Luckilly undoing it set things back to normal. Others have had more severe problems so I would not suggest it.
Instead I ended up installing a relay to my new HID fogs with the trigger wire hooked up to the parking lights. That way they stay on as long as the parking lights are on (including when I have the high beams)
Giggity
spta97 is offline
post #3 of 8 (permalink) Old 09-27-2011, 08:58 PM
Kooshtaka's Avatar
Quoted: 103 Post(s)
Spta did you/can you write up a how to? I hate it when my fogs turn off while having brights on... arrgg... lol
'05 Mada LE Slate
Kooshtaka is offline
post #4 of 8 (permalink) Old 09-27-2011, 11:16 PM
spta97's Avatar
Quoted: 81 Post(s)
I didn't make a write-up but I can (with limited pics of course as it's already complete). Are you keeping the OEM fog light bulbs or are you using HIDs?
Reason I ask is because you would have to either get / make a connector to the factory bulbs or cut the existing harnesses if you are using OEM.
If you haven't done the HID upgrade I would highly recommend it. Most people here use ArmaDen (member of the forum). He has good prices and a good product. He can also hook you up with a relay and harness for your new fog light HIDs
I have the HID low beams and fogs, Silverstar highs (meh) and 130watt KC HiLite Long Range lights on my bull bar that turn on with my high beams:
I should note that it is illegal to have more than 4 beam lights on at a given time so cops can give you a hassel.
Giggity
spta97 is offline
post #5 of 8 (permalink) Old 09-28-2011, 02:14 AM
drewcs's Avatar
Wow! That's bright! I'm interested in your fog HID's and relay setup. Don't you have the plastic lenses? And if so, does Armaden now have a proper bulb for the oem housing to avoid the melting issue?
'06 LE, Airaid MXP CAI w/dry filter - BullyDog GT w/regular tune - 20" Titan wheels w/Cooper ATP's - Int/Ext LED conversion - 5000K HID low beams - Bilstein HD - Amsoil Synthetic everywhere - Power Stop drilled/slotted rotors w/ceramics pads
drewcs is offline
post #6 of 8 (permalink) Old 09-28-2011, 08:36 AM
spta97's Avatar
Quoted: 81 Post(s)
Ha ha...yea it's awesome. My only issue is that I still get some vibration on the bull bar lights but it is much better since I put some rubber pieces under them to act as isolators (I used the things you put under chair legs so they don't scratch wooden floors).
I do have the plastic lenses but I have not had an issue. I tried a glass housing from Pilot but I could not get the HIDs to fit as they were too long (even the short ones he sent me). The HIDs run cooler with less wattage but apparently some have issues because the bulb length gets it closer to the plastic lamp cover. I have had mine on for months and have no issues. On my 07 the OEM bubs were 37.5 watts whereas others had 25 watt OEM bulbs so perhaps the housing is made of a different material?
I'll write up something for you but I'll need a day or so.
Giggity
spta97 is offline
post #7 of 8 (permalink) Old 09-28-2011, 02:15 PM
drewcs's Avatar
Lol... I have different size clear ones all over my truck to stop the squeaks and rattles! On almost every bin, sunglasses holder, cup holder cover, sunroof cover...you name it. They're great! And the write up would be greatly appreciated. Thanks.
drewcs is offline
post #8 of 8 (permalink) Old 10-23-2011, 12:23 PM
spta97's Avatar
Quoted: 81 Post(s)
Sorry for the delay - I did a write up and posted it here
https://www.clubarmada.com/forums/sho...542#post185542
Giggity
spta97 is offline
