How to fix condensation in headlight - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 4 (permalink) Old 01-23-2012, 01:03 AM Thread Starter
usedsoup's Avatar
I have been having condensation in my right side head light for 3 months now and I finally had enough. So after reading a few other forum article about how to take care of it I decided to go with the complete removal and resealing.
Here's how I did mine
Tools 8,10 mm wrenches and sockets, screw driver, clear or black rvt silicone.
1. Pop hood and remove plastic guard on the inside border of the light, then there are two bolts that can be removed very easily. Also disconnect the electrical connector to the lights.
2. Turn the wheel pointing in on side you are working on. Remove the wheel well cover (I just pulled it back a little). There are two more bolts to remove from this location.
3. The last bolt I found easiest to access from under the front. It is visible from the top but coming from the under side might be the only way short of taking off the bumper to get it out.
4. It takes a little finagling to get the assembly out but it comes out with out taking bumper off. Removed the lights, the QX has 3 small bulbs, a high beam, and the xenon. I poured out about 1/2 cup water that had been siting inside the assembly.
5. I stuck the assembly in a 250 degree oven for 30 min with a moist towel wrapped around it to protect the plastic. After baking, the two parts came right apart after working the clips loose. Cleaned out all the old silicone and put some new stuff in there. Probably used to much but I did not want any water back in there. Be super careful about touching the inside of the lens. I found a smudge from my finger after I put it back together.
6. I let it set overnight and put it back in the next day. Looks good as new.
Its been 3 weeks now with no new water.
ID:	10455   Click image for larger version
ID:	10457   Click image for larger version
ID:	10458   Click image for larger version
ID:	10460   Click image for larger version
Nate
usedsoup is offline
post #2 of 4 (permalink) Old 01-23-2012, 07:31 AM
Scorpion's Avatar
Good job bro
Sent from my Autoguide iPhone app
2012 Titan PRO4X S&B cai, 2* Advance Timing, 6500k HID, 1000w sub with 500w rms amp, 18" XD RockStars with 33" BF Trails, BD GT, Volant Double Exhaust,
LED interior,
------------ROB-------------
Scorpion is offline
post #3 of 4 (permalink) Old 01-23-2012, 09:49 AM
AngelVivas's Avatar
Thanks for the helpful post.
Angel Vivas, III
2006 Nissan Armada SE 4x2 Silver Lightning
UPRev Tuned (Cajun Style)
Gibson Cat-Back Exhaust
Cajun Catless B-Pipes
Volant Cold Air Intake
CSF 3328 Racing All-Aluminum Radiator
2" Front Leveling Kit (To Even Her Out)
Bilstein HD Front Struts
Interior LED Kit
6000 HID Kit
Nissan Black Grill Guard
AngelVivas is offline
post #4 of 4 (permalink) Old 01-24-2012, 04:01 PM
good work. from one retrofitter/headlight light opener (is that a phrase?) to another, i know how difficult and stressful the headlight baking process is. looks like you did a great job sealing and aligning the lens back in place.
:: custom made projector headlights (fxr 3.0 projectors, philips 85122+ bulbs) :: air box "mod" :: 5000k HID fogs :: interior/exterior LEDs ::
:: 20% tints :: OEM remote start :: GO-RHINO chrome rear step :: tinted tails ::
:: 2012 Armada Platinum :: 2011 Infiniti FX50 :: 2011 Nissan Maxima ::
12platinum is offline
