2008+ Headlight removal - moisture in headlight issue remedy/repaired - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 11 (permalink) Old 02-13-2015, 10:54 PM Thread Starter
Hi everyone,
Not new to Nissan, not new to mods, repairs and how to's:
I purchased a used 2011 Platinum and i noticed the moisture in the headlight right off - Drivers side only was affected on the Armada I purchased.
in the images below i try to keep colors and shapes the same, for ease of the how to and reference:
PIC1 - FACTORY SERVICE MANUAL:
-Ok, notice that the service manual view only shows the front of the grille....its hard to tell, but the yellow dashed lines i overlayed the FSM dashed lines to help show that they are trying to depict the lower 3 clips.
- all the clips can be removed with the hood up top side, some you have to reach through the grille itself.
- you can use a flat head screw driver and simply push the square/diamond portion of the GC101 clip over to the side to free the grille.
PIC2 - GRILLE REMOVED FROM CHASSIS:
-in this picture i show the red circles as where the clips are located. i checked on my armada and another friends, and the two outer lower clips are not there - they are depicted by the "red X".
- the green circles are actual metal clips - they usually come free when you pull, but for me the passenger side one stayed stuck and took some time to free it by wiggling and reaching back there with a small screw driver.
- the blue circles are simply alignment points, keep mind of these when reinstalling the grille.
YELLOW ARROWS:
----- So this is where water enters the headlight assembly. I studied tons of threads, read nearly every single one, looked at 3 other armadas i saw that had leaking headlights along with very close review of my removed headlight you can easily see that the top is lacking adequate sealant squeeze out of the factory silicone and the design with its sloped contour easily lets water collect...ill post on this more in threads to come.
PIC3 - GRILLE REMOVED AND REAR VIEW OF GRILLE:
- this is the grill removed. again here i show where the CG101 clips must be put back in. simply snap them in the red circle locations and you will have the grille prepared to be snapped back in.
--- remember when your done and ready to snap the grille back in, start with the bottom, and ensure all the bottom green circle and blue circle alignment points and clips are in place, then push the upper CG101 clips in.
PIC4 - GRILLE CLIP GC101:
- this is what the grill clip CG101 looks like reinstalled back onto the grille.
-J
Name:	FSM Image1.jpg
ID:	25874   Click image for larger version
Name:	Armada Grille Removed.jpg
ID:	25882   Click image for larger version
ID:	25890   Click image for larger version
Jasontamu is offline
post #2 of 11 (permalink) Old 02-13-2015, 10:55 PM Thread Starter
Removing the wheel well liner:
Where to start on wheel well liner:
- I didnt take pics till i got to the passenger side, but start by removing the philips screws shown in yellow circles.
- the green circle is a 10mm hex head screw on a tab from the front bumper, mine was broken, but the sheet metal clip under still needs to be removed.
PIC - LINER PULLED BACK:
-PULL BACK THE LINER WITH THE WHEEL TURNED IN.
PIC - LINER PULLED BACK AND TWO SCREWS SHOWN:
-Green square - 8mm hex screw facing forward, so you have to get a small ratchet wrench and reach to the front and work from behind, once its loose, you can hand turn it free.
- red sqaure - 10mm hex screw - need a goose neck wrench - ratcheting is nice...
-J
Name:	Wheel well liner1.jpg
ID:	25906   Click image for larger version
Name:	wheelwell liner2.jpg
ID:	25914   Click image for larger version
Name:	Wheelwell liner3.jpg
post #3 of 11 (permalink) Old 02-13-2015, 10:56 PM Thread Starter
Headlight - now you simply have one other screw easily seen on top.
Top screw has a washer under it:
metal threaded nut clip on oem headlight assembly:
-I had to remove this metal threaded clip and install it on the aftermarket headlight i purchased. it didnt come with this one location.
Name:	Washer location.jpg
ID:	25930   Click image for larger version
Name:	threaded nut clip reuse.jpg
post #4 of 11 (permalink) Old 02-13-2015, 11:08 PM Thread Starter
Sealing the newly purchased headlight and the existing unaffected passenger side headlight.
so, in carefully looking over the entire headlight - like i mentioned before you can see the sealant squeeze out is generous along the sides and bottom of the oem headlights, but the top is minimal squeeze out and with its sloped design easily lets water gather and eventually penetrate the headlight assembly.
i simply purchased black silicone RTV and generously added it to ever sealed edge - i did this with both head lights removed since i already had the grille off and the wheel well liner screws off, etc.
headlights with sealant added:
hood contact area:
When you do this mod, ensure you wait till the black silicone is fully cured before you lower the hood, otherwise, the next time you open the hood you will get black gunky mess on this location on the underside of the hood. just fyi.
-J
Name:	headlight seal Drivers side.jpg
ID:	25946   Click image for larger version
Name:	headlight seal passenger side.jpg
ID:	25954   Click image for larger version
Name:	hood seal contact area.jpg
post #5 of 11 (permalink) Old 02-13-2015, 11:15 PM Thread Starter
Reason why our armada headlights get moisture inside them
- so in reviewing you can easily see that the design just simply doesn't help the situation.
the headlight by design just happens to be sloped and a perfect water collection point due to the hood to fender gap that makes up the body of the armada.
- that plus the lack of sealant squeeze out results in eventual penetration..its pretty much why you dont see moisture headlights at the dealership, it takes time for new armadas to gather water and penetrate the sealant...usually after a few years ownership this issue arises right - well seems so from all the threads and searching i did of others with the same issue.
See the geometry of the headlight sloped area here:
Hood gap to fender water entrance location:
So.:
If you have an armada that hasnt leaked yet - i say dont wait, and simply with out removing the grill, or anything, simply lift the hood, buy some black RTV and seal this entire top area, get back under the fender as much as possible and i bet you wont ever run into this problem EVER!
-J
Name:	Water valley penetration point1.jpg
ID:	25962   Click image for larger version
Name:	water penetration point2.jpg
post #6 of 11 (permalink) Old 02-13-2015, 11:22 PM Thread Starter
headlight assy differences
so, on the box i received, it was labeled as eagle eye light assemblies...some aftermarket manufacture of headlights, oem replacement unit. ebay.
OEM headlight pitch adjuster:
Ebay aftermarket adjuster:
- the black square is the screw that had a washer under it - mentioned in the post above where im wearing the gloves. better pic here.
Ebay vendor where i got drivers side the light assembly:
hope this helps others...the many post i read on this issue lead me to how to fix it, along with the better understanding of why it happens in the first place......
i read all the threads where others took their assy apart and simply dried them out and re-sealed and reused them with no issues, i didnt have time to include the oven method of taking the headlight apart.........buying a replacement let me do this swap one afternoon after work.........
ill probably dry out the oem removed headlight, seal it up and save it in case i ever break a head light or something.
-J
Name:	oem adjuster1.jpg
ID:	25986   Click image for larger version
Name:	aftermarket adjuster2.jpg
ID:	25994   Click image for larger version
Name:	ebay headlight.jpg
post #7 of 11 (permalink) Old 02-13-2015, 11:39 PM Thread Starter
Done..finally..
post #8 of 11 (permalink) Old 02-14-2015, 12:36 AM
Rumplecat's Avatar
Quoted: 44 Post(s)
Great write up!
Rumplecat is online now
post #9 of 11 (permalink) Old 02-14-2015, 08:31 AM
keg97's Avatar
I had this issue with our QX and handled it over Christmas. Although the bumper/grill is very different, the cause is much the same. I also used rubber sealant (I had to dry out my headlight first though) and have had no issues since.
2008 Infiniti QX56 4x4 (Tuscan Pearl/Wheat), 2009 Audi Q7 S-Line (Daytona Gray/Black), 2009 Infiniti G37xS (Garnet Red/Stone), 1994 Mazda Miata (Laguna Blue/Black), Previous Nissans:, 2001 Nissan Pathfinder LE 4x4 (sold 2/08), 1993.5 Infiniti G20-manual (RIP 7/8/04)
keg97 is offline
post #10 of 11 (permalink) Old 02-14-2015, 10:04 AM Thread Starter
^ ya if i had more time to do these kind of things i would have simply taken mine apart and dried it out and reused my light and sealed it up for reuse........I was able to do all of this in about 1 hour total taking my time. I just left my hood up for an extra hour before closing it because I didnt want the wet sealant to get all over the bottom edge of the hood.
-J
