LED Light Bar installation Photos in bumper - wiring questions/suggestions - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 7 (permalink) Old 11-27-2016, 08:16 PM Thread Starter
Question LED Light Bar installation Photos in bumper - wiring questions/suggestions
(I saw a lot of reads on this, but no reply, so I'm adding this note: I've got a question / suggestion requests on how to best wire this up. See below)
I'm tired of surprises from the wildlife around here, so I decided to add lighting. I've now got a 23" LED light bar that I just mounted in the bumper lower air intake of our 15 mada.
So nice of Nissan to have put 3 pin clips there (one centered, other 2 19 inches apart) which made mounting of this bar (which has 2 adjustable sliding mounts) a cinch after removing the front grille (just clips).
My wiring plan is as follows:
1. Hot from battery to Relay #1 (with a 30A fuse between them) so the bar has it's own power and isn't sharing
2. Relay #1 controlled by tapping into the power going to one of the brights bulb
3. Relay 1 sends power to Relay #2 (maybe with another 30A fuse - necessary? recommended?)
4. Relay #2 controlled by in cabin switch (which will be connected to 12v in cabin)
5. Relay #2 sends power to the bar
This way the LED bar cannot be on unless the brights are on AND the in cabin separate switch is on. Turning off the brights will automatically turn off the LED bar which makes turning it off quick and safe when necessary - no fiddling for a switch. When on road, the in cabin switch can remain off for normal use of the brights.
Questions:
1) I don't mind having 2 relays, but am all ears if there's a better way to wire this up. My only requirements are a) safety and b) having the bar turn on and off with the brights with an override off switch
2) I'll likely tap into the bright's power line using a T splicer since there's just not any excess wiring (and it's easy). Does anyone know what gauge wire feeds the high beam bulb?
Name:	Light Bar In Bumper.jpg
ID:	37833   Click image for larger version
Name:	Light Bar In Bumper 2 .jpg
ID:	37841   Click image for larger version
Name:	Light Bar Mounting.jpg
weinberk is offline
post #2 of 7 (permalink) Old 02-03-2017, 10:10 PM
How sturdy is it? Which brand of LED did you pruchase. Does it impede airflow?
2015 Nissan Armada Platinum Arctic Blue. U3 Canbus Led Fog and Low Beams, Silver Hyper Star high beam. XPel Ultimate, Nissan Bug Shield,
Wish list: Magnaflow cat back exhaust- 3 days away! Volant CAI, 2" Lift , 295 tires
Extremearmada is offline
post #3 of 7 (permalink) Old 02-04-2017, 04:21 PM Thread Starter
I got one like this:
http://www.ebay.com/itm/7D-23inch-32...xX~z3G&vxp=mtr
No movement at all even over rough (paved) road. I haven't used it in warm weather, but I don't anticipate any issues with airflow.
The mounting location does mean that if it's snowing hard enough, snow will build up on the bar and make it pretty useless, but I don't think I'd want such a bright light on during snowfall anyway.
I've installed it with 2 relays so that it's only on if the brights are on AND the switch for the bar is on. That means I can have the switch on (ready to go) and the bar will turn on and off with the factory brights lever. Convenient.
weinberk is offline
post #4 of 7 (permalink) Old 02-04-2017, 04:26 PM Thread Starter
I'd love to see some photos of your U3 installation fogs and lows and the silverstar highs. Really don't like the yellow colors factory lights. Do you have photos posted anywhere?
weinberk is offline
post #5 of 7 (permalink) Old 02-05-2017, 03:13 AM
I don't have any pics but the U3 are brighter than the HID I had in the past. Agai. The issue is the reflection during heavy snow storms. It was difficult to see. Looking at amber overlay on the fogs from Laminx
post #6 of 7 (permalink) Old 03-31-2017, 01:14 AM
Invanity's Avatar
Frankly, I think its a solid setup and pretty convenient if you don't want the LED bar on with the high beams on all the time. Im about to do a similar mod with my lights but might turn mine on with the fogs or as you with the high beams....I just need to see how bright they are.
Anyways the gauge of the high beam light wire (our control line) shouldn't matter as there isn't very much additional load on it to simply engage relay #1 - well I guess I would need to know the relay PN so I can look up the specs on it and see where its triggered but generally it doesn't take much to engage the relay. The gauge wire that really matters is the wire (load line) that's hooked into the battery but you also have that protected with a 30 amp fuse.
-Eli
Thanks guys
Invanity is offline
post #7 of 7 (permalink) Old 04-19-2018, 05:31 PM
ArmaSwede's Avatar
Hi, I have a 20" led light bar installed with one relay. It is controlled by the hi-beam but I also have a switch under the dash that can turn it off.
I also got a short extension wire for the hi-beam that made install possible without splicing into the factory wiring.
ArmaSwede is offline
