Need Help - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 6 (permalink) Old 05-10-2007, 09:00 AM Thread Starter
Need Help
Installing Alpine Navigation Nve851a And Alpine D100 .. Need To Find Out What Wire Is The Brake Lamp Wire And The Emergency Brake Wire And Reverse Lamp Wire On My 2004 Nissan Armada. Can Anyone Help ? Thanks
arod36 is offline
post #2 of 6 (permalink) Old 05-10-2007, 12:09 PM
Someone who has installed units such as this will be of more help than me. But here is some info:
The brake light wire can be found at the brake light switch located near the top of the brake pedal are. There are two switches mounted there, one for the brake light and the other for the cruise control. The wire you want to connect to is red with a green stripe.
The parking brake wire can be found at the switch on the parking brake. It is a green wire.
The backup light wire can be found at a couple of locations. It is the green wire with a white stripe that goes from the backup light relay in the relay box under the hood to the backup lights, or the yellow wire with a red stripe that is in the harness to the trailer plug.
post #3 of 6 (permalink) Old 05-10-2007, 04:03 PM Thread Starter
thanks for the info....looks like this will help me alot
arod36 is offline
post #4 of 6 (permalink) Old 05-10-2007, 04:34 PM
Buy the PAC Audio TR-7 Bypass off of ebay. It is a lot better then using the ebrake/foot brake method that Alpine requires you to use. As for the reverse wire, you don't need it unless you are hooking up a back-up camera, you do not drive in reverse enough for the GPS to even notice. One note on the TR-7, only hook-up the head unit wires to it, you can just ground the Navigation ebrake wire on that unit.
2007 Red Brawn LE 4x4.
MODS:
AVIC-Z2 w/Bluetooth and XM NavTraffic, Pac SWI-PS, Alpine Type-R Sub w/ MRD-M605 AMP.
Future MODS:
Remote Start/Alarm, Wheels, Rear Entertainment Screen(s) and Wood Dash Kit
BacaraArmada is offline
post #5 of 6 (permalink) Old 05-10-2007, 06:57 PM
baseballfanz's Avatar
Reverse wire can be found inside the passenger side kick panel. I'm not sure about the Mada but my Titan has a harness there that contain the reverse wire.
baseballfanz is offline
post #6 of 6 (permalink) Old 05-11-2007, 02:23 PM Thread Starter
thank you club armada saves the day again
arod36 is offline
