Did a coolant flush this past weekend - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 3 (permalink) Old 10-14-2018, 10:54 PM Thread Starter
Flushed the coolant on my 2010 Armada Platinum this past weekend (sorry didnt take pics)
Pretty much dropped the skid plate an on the bottom right corner of the radiator there is a plastic valve. I opened that an the coolant started draining taking off the radiator cap will also help it drain. I disconnected the clamp from the overflow bottle an also allowed that to drain. Closed everything up an filled it with distilled water, about 1 1/2 gallons. Started the truck an turned the heat on max. I let it run for about 10 minutes then shut it off allowed it to cool. Drained the distilled water out an filled it with OEM Nissan fluid(blue). While you are filling it you can squeeze one of the upper radiator hose to help "burp" any air out. All in all I bought 2 gallons an used about 1 1/2. Pretty straight forward job that can save you about $50-100 D.I.Y
This car is what I look like on the inside.
BLK_ON_BLK is offline
post #2 of 3 (permalink) Old 10-15-2018, 09:24 AM
SE Off Road1's Avatar
Quoted: 58 Post(s)
No need to remove hose from the expansion tank it will drain back into the radiator. Easy way to purge air in the system is keep expansion cap off and topped off to the full line while running the engine and coming up to temp. Allow truck to come up to normal temp and turn heater on high while the t-stat opens and closes a couple times. While doing this process keep an eye on the gauge to ensure it is not running hot or worse overheating. Do not shut off truck once complete until the expansion pressure cap is returned. Once cap is replaced take it for a ride and make sure temp stays in normal range on gauge.
SE Off Road1 is offline
post #3 of 3 (permalink) Old 10-15-2018, 10:49 PM Thread Starter
Will remember this next time I do it. Drove it around after I finished temp looked fine, will keep a eye on it next upcoming days.
