Loose Front Seat Repair - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 6 (permalink) Old 11-09-2018, 04:24 PM Thread Starter
Post Loose Front Seat Repair
Hi,
Ever since I purchased my 2008 QX56, I had a slightly loose Driver Seat. It didn't move very much it all, but i felt it every time I was braking a bit harder or accelerated. It was just a slight little clunk and movement in the entire seat. At first I suspected a worn out rubber bushing that rides on the electric motor adjustment screw for the forward and backwards movement of the seat. After all, the car has 183K on it.
So today I decided to take the entire seat out of the car and give it a good look over. I quickly discovered that it was in fact the entire screw shaft the motor turns in order to move the seat, that had a bit of back and forward play in it.
All I had to do was tighten that little Allen head screw in the middle of the face place of the motor. Be sure not to tighten it too much as that will lock up the motor from turning and burn it out. You want it to be as loose as possible without creating any excess slop. The best part, is that you don't even need to remove the seat in order to make this adjustment.
ID:	45011   Click image for larger version
sswiss is offline
post #2 of 6 (permalink) Old 11-09-2018, 06:06 PM
1lowcab's Avatar
Quoted: 25 Post(s)
Awesome!
I'm going to try that on my 08 Armada as it does the same thing.
08 Armada 4x4 SE K11 Smoke Grey
Bully Dog GT, Airbox Mod, Running Board Delete, Tinted Headlights + Taillights, Alpine Type S 10" Sub + Alpine MRV Amplifier
1lowcab is online now
post #3 of 6 (permalink) Old 11-09-2018, 07:17 PM
Can you do that without removing the seat?
post #4 of 6 (permalink) Old 11-09-2018, 08:16 PM Thread Starter
Yes, All you need to do is look under the front of the chair. You might have to un-clip the side cover from the front and pry them a bit apart. That will give enough access to tighten it up
sswiss is offline
post #5 of 6 (permalink) Old 11-18-2018, 07:08 PM
1lowcab's Avatar
Quoted: 25 Post(s)
Just did it to mine and now the seat feels like a new one!!
Super easy to do, took like 1.5 minutes, lol!
Good job on finding the fix, this should be a sticky.
post #6 of 6 (permalink) Old 11-19-2018, 10:32 AM Thread Starter
1lowcab, I am glad it worked for you. It's amazing how such a little thing can be so annoying
sswiss is offline
