2008 Procedure for 2 degree timing advance - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 19 (permalink) Old 01-09-2008, 11:04 AM Thread Starter
Many of us have had good results advancing the initial timing by 2 degrees. Listed below is the procedure to make the advance, using the Consult 3. You will need a Nissan dealer to do this. You should print out the procedure and take it with you to the dealer.
Warm up vehicle.
After consult3 has connected to car :
1. Press Wrench sign upper Right side of screen.
2. Press ECM/Wrench sign just below Large Wrench sign
3. Press Engine / OK
4. Work Support
5. Engine Timing at bottom of list
6. Follow prompts to +2
7. Press UPDATE
!!!!!! make sure they actually hit the UP-DATE BUTTON !!!!!!
or it will not save..
Make sure engine is at normal operating temp. & also good to reset
Idle air volume relearn to @ 650 rpm with a/c off & steering wheel straight..
Originally Created by tazstitan: http://www.titantalk.com/forums/1045475-post14.html
Here's before and after 1/4 Track Timeslips.
post #2 of 19 (permalink) Old 02-27-2009, 02:49 PM
The Jonah's Avatar
Pops,
I need to go to the dealer for an oil change shortly, so I wanna run this by the tech there and maybe slip him a $20. Has the procedure changed or will these work still? Also should the car be turned on/off? Reason i ask is because you stated this:
Thanks for your help. jP
The Jonah is offline
post #3 of 19 (permalink) Old 03-26-2009, 06:26 PM
Is this the same for the 08 and up Armadas?
pi3yeargrad is offline
post #4 of 19 (permalink) Old 03-26-2009, 08:44 PM
Yes............
post #5 of 19 (permalink) Old 03-26-2009, 09:57 PM
what does this do to your gas mileage?
drakethib is offline
post #6 of 19 (permalink) Old 03-27-2009, 07:56 AM
Quoted: 281 Post(s)
you use more gas so it suffers a bit.
post #7 of 19 (permalink) Old 03-27-2009, 09:28 AM Thread Starter
My MPG improved a bit after doing it. It really depends on your driving habits more than anything.
post #8 of 19 (permalink) Old 03-27-2009, 09:48 AM
My mileage definitely improved when I am not being aggresive in my driving. Vehicles runs more efficient and the accelerator is more responsive. However, if you are a little on the aggresive end of the spectrum and love to speed (which my leadfoot havin' @$$ got a ticket recently), you will experience a little drop in MPG.
post #9 of 19 (permalink) Old 09-14-2009, 09:45 AM
paulieb's Avatar
It's all about how you drive it, my mpg improved as well but I may be more aware of how I am driving now.
2008 Galaxy Black LE 4x4 "ELVIS"
Premium Package
Technology Package
Towing Package
2Degree advance
Burtman Rear Spoiler
paulieb is offline
post #10 of 19 (permalink) Old 12-23-2009, 04:42 PM
what is the reason for advancing the timing +2?
littledrummerman is offline
