Auto Level Suspension Problem - Exhaust Solenoid always on - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 4 (permalink) Old 05-24-2018, 12:06 AM Thread Starter
DirtBiker's Avatar
Hello,
Looking for some ideas on how to solve a problem where the exhaust solenoid is on all of the time. Compressor never runs and never gets 12V from relay to turn on.
- Exhaust Solenoid clicks on after 30 seconds and stays on
- Always measuring 8V on the connector to the exhaust solenoid even after 10 minutes.
- All fuses good
- Swapped the 4WD and compressor relay next to battery - no difference
- Unhooked level sensor and manually moved level arm to try and kick on compressor - no difference
- Measuring changing resistance from the level sensor with meter. Resistance changes consistently when moving leveler arm, but I don't know the spec.
- Replaced the suspension control unit with an Ebay one - no difference
My next step is probably to change out the level sensor, but I'm hoping maybe there are some other ideas out there.
- 11 Armada Platinum, 4WD, Galaxy Black
- 14 Coachmen Liberty Express 310BHDS, 35', 7400#
DirtBiker is offline
post #2 of 4 (permalink) Old 05-24-2018, 09:35 AM
m3bs's Avatar
Quoted: 22 Post(s)
My sensor measured from 500 to 2500 ohms, decreasing with higher suspension level. It was about 1600 at normal ride height. Don't know if that helps, but....
m3bs is offline
post #3 of 4 (permalink) Old 11-04-2018, 02:50 PM
Adamsb3715's Avatar
Have you tried putting 12v directly to the compressor to verify that it does work. Also sounds like you SOV is going bad or is back(sticking or with not hold)
Adamsb3715 is offline
post #4 of 4 (permalink) Old 11-05-2018, 07:17 AM Thread Starter
DirtBiker's Avatar
It ended up being a bad level sensor. I replaced it and everything fired back up.
Thanks everyone for the ideas.
