2nd Gen Armada brake pedal play - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 2 (permalink) Old 10-04-2018, 10:32 PM Thread Starter
Well we bought a 2018 former rental Aramada SV 4WD with a whopping 36000 miles.
The only issue other than very soft paint and chips is that the brake pedal has about 3mm of play at the top of the travel. I can see the play is due to a sloppy fit between the yolk and the pin up above the pedal.
Does anyone else have similar play in their pedal? Do you know if it is any intentional design critical to braking (like unloading a sensor)? If the play is not required, has anyone determined if the play is removed by replacing the pin, the yolk, the insert tab or some combination of these?
ric200 is offline
post #2 of 2 (permalink) Old 10-05-2018, 09:36 AM
Curious, did you take it to a nissan shop to get it checked out prior tp purchase? Or your trusted mechanic?
The brake pedal should not have any “play” in the movement. No wiggle, no lag in the physical movement.
You should have your brake system checked out.
