Electrical issues.. HELP!!! - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 3 (permalink) Old 03-16-2019, 04:42 AM Thread Starter
So here’s the deal I have an 05 it’s got 215k miles. I bought it knowing it had some issues. It was running rough and had no power. I verified that cylinder 1 was not firing by pulling the coil plug and no change in the engine. In trying to verify if I had power coming to the cylinder 1 plug I shorted something out and now it won’t run at all. Two things to note. Number one: The anti theft left remains solid red when the key is turned to the on position. Is that normal or an issue with the anti theft system possibly? Number two: the cel does not light up at all. Under normal operation the cel will light up before starting the vehicle which it does not do now. Also when I plug a scanner into the obdII port I have “power” but I do not get a signal from the computer. All other dash lights are working. Along with all the accessories. Headlights, turn signals, radio, rad fan, etc. My fear is I may have fried my ecu? I have double checked all the relays and fuses that I know to find. My hope is I am missing a fuse somewhere? Are there any relays or fuses that are hidden from plain sight in the fuse and relay areas? If something is fried is it more likely the IPDM, or the main ecu? Any suggestions would be appreciated!!
Armada12 is offline
post #2 of 3 (permalink) Old 03-16-2019, 01:28 PM Thread Starter
Anyone have any recommendations on a good company to check the ecu for damage?
Armada12 is offline
post #3 of 3 (permalink) Old 03-17-2019, 10:28 AM
gt601's Avatar
Quoted: 24 Post(s)
I know that Uprev can reflash but if the ecu is fried that probably isn't an option.
Maybe talk to someone at the dealer for some pointers?
Paul
gt601 is offline
Nissan Armada 2012 SE Owner with few electrical issues viking7833 New Member Introductions 0 01-23-2018 07:26 PM
Help several electrical issues astribs Problems 5 09-16-2014 01:00 AM
Please help. Vdc slip abs cruise + tranny slip and electrical issues Chillibear Problems 2 07-22-2014 01:03 PM
2008 Armada Electrical Issues?? BigBlack08 Problems 10 08-22-2012 02:40 PM
Electrical issues ffbones Problems 3 02-19-2010 09:22 AM
