Power lift gate issue. HELP needed - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 3 (permalink) Old 04-13-2019, 08:15 PM Thread Starter
Hey guys, my '12 Platinum has the power lift gate. I'm having some issues with it. If I pull on the gate handle, it doesn't do anything. If I use the remote, or the dash button, the hatch opens 3/4 of the way, bounces violently, then closes and latches by itself. While closing, it beeps at me to tell me something is wrong.
The cancel button is not stuck, and I can't find any object or dirt that is interfering with the gate or the arm.
Once the gate has closed itself, it refuses to open again u til I turn the 'mada off and on again. Then does the same thing
Has anybody expertise this or heard of a solution? ?
There are dozens of posts about the power gate not working at all, but I have not found a mention of this issue.
Please help
Dustin
ProjectBeaumont is offline
post #2 of 3 (permalink) Old 04-14-2019, 03:00 AM
Try opening the gate manually. You should be able to pull on the handle and then lift it . Once you have it open see if it will stay up on its own. I'm guessing your struts are weak and the motor doesn't have the power to lift the weight of the hatch without the help from the struts. Replacing the struts is easy.
post #3 of 3 (permalink) Old 04-15-2019, 01:17 AM Thread Starter
Hey Keith, thanks for posting a response. I do not believe the issue is the piston struts, howerever I will check them to eliminate the possibility. I hope it turns out to be something that simple
I am actually wondering if the lift gate or the actuator arm assembly have a position sensor or an impact sensor or something. The gate opens strong 90% of the way smoothly as it always has. The bouncing looks like it is caused by the actuator itself, it takes a large amount of force to bounce the door the way it does. It seems like the motor reverses direction a number of times very quickly. This appears to take a lot more force than just opening or closing the gate slowly.
Tail Gate / Lift Gate Fix vwchisme Problems 15 12-26-2017 02:30 PM
Lift Gate Issue with a twist drrama.scrr Problems 1 08-28-2017 08:19 PM
Lift Gate Issue allwat Problems 2 02-01-2016 12:44 PM
Help with power lift gate Mrhavasu General Discussions 10 03-29-2010 07:27 AM
Help with power lift gate Mrhavasu General Discussions 25 12-29-2007 08:13 PM
