Power Lift Gate Issue - 2005 Armada LE - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 1 (permalink) Old 04-16-2019, 03:31 PM Thread Starter
Question Power Lift Gate Issue - 2005 Armada LE
Hello everyone, I have a 2005 Nissan armada le 4X4 with over 170K miles. I'm having issues with the Power Lift Gate that won't open with remote or with front & back buttons on vehicle. I checked the actuator which looks to be working. The actuator will lock & unlock with remote. There are two cables on actuator. Cable from actuator to rear window which is attached and cable from actuator to rear handle lock which is MISSING. I assumed since this is a power driven lift gate, that cable would not be needed or connected. Am I correct? The Power Lift Gate struts are ok because I can manually open the door and it will stay open. I can't hear any noise from motor because it will not operate.
I Was looking thru the forums and someone mentioned the micro switch sensor in back of handle on door. Say's when it goes bad the motor will not activate. Dealer wants to charge for complete handle assembly that includes micro switch. Micro switch is available by itself for about $8.00. Can this switch be replaced and would I need to do any soldering to replace it. Note: Ref: Micro Switch P/N SAIA-BURGESS V4LST7/
Vger2 is offline
Power lift gate issue. HELP needed ProjectBeaumont Problems 2 04-15-2019 01:17 AM
Tail Gate / Lift Gate Fix vwchisme Problems 15 12-26-2017 02:30 PM
Lift Gate Issue allwat Problems 2 02-01-2016 12:44 PM
04 LE power lift gate Driftwood Problems 5 11-22-2012 10:12 PM
2005 Armada Lift Gate Problem iduate Problems 10 09-11-2012 01:01 PM
